New added product preview image (in 720) is not shown in product details page.
Re: New added product preview image (in 720) is not shown in product details page.
Post by aimeos » 14 May 2024, 07:37
Did you enable/change the ASSET_URL in your .env file?
https://github.com/aimeos/aimeos/blob/m ... example#L7
If yes, try to remove that setting as it's only useful for remote cloud storages
Sabir_Ali
Post by Sabir_Ali » 14 May 2024, 08:22
No. I did not edit it. Today I was trying to use it but I get only loosing all styles and media on the site.
Is there any file system configuration (I mean config/filesystem.php or somewhere else) to redirect storing media files on adding new products?
Post by aimeos » 14 May 2024, 08:58
The base URL for images is defined here:
https://github.com/aimeos/aimeos/blob/m ... p.php#L137
In the templates, the real URLs are created by calling the "$this->content()" view helper, e.g.:
<img src="<?= $enc->attr( $this->content( $mediaItem->getPreview(), $mediaItem->getFileSystem() ) ) ?>">
See: https://github.com/aimeos/ai-client-htm ... hp#L51-L54
The filesystem column in the mshop_media table must contain "fs-media" for images.
For responsive images with srcset, the "$this->image()" view helper takes care about creating the real URLs:
- https://github.com/aimeos/ai-client-htm ... ge.php#L27
- https://github.com/aimeos/ai-client-htm ... rd.php#L55
Sabir_Ali
Post by Sabir_Ali » 15 May 2024, 06:57
Yes. The solution accepted by us is changing default directory for media files in config/shop.php in 'fs-media'.
Thanks a lot!
Sabir_Ali
Post by Sabir_Ali » 15 May 2024, 13:43
But I forgot one thing. How to add the following configuration as external
'common' => [
        'media' => [
            'product' => [
                'previews' => [
                        'maxwidth' => 720,
                        'maxheight' => 960,
                        'force-size' => 1,
to avoid edit configuration in the aimeos-core/config/controller.php?
Post by aimeos » 16 May 2024, 06:20
Add that configuration to your ./config/shop.php
Sabir_Ali
Post by Sabir_Ali » 17 May 2024, 08:48
I asked this question about configuration because I was trying to use this approach before, and had no result. I know, that this is normal practice to use config/shop.php file to add our own configurations. But it doesn't work for me. I spent almost two days in searching a way to merge this configuration.
So, I tried many ways, like using merging in shop.php, app.php, Service Provider, Extension Service Provider. And now I'm trying Decorator but still in process.
It looks like configuration aimeos-core/config/controller.php loads after all cached configurations at runtime. The key method that need this config is createPreviews() in src/Controller/Common/Media/Standard.php (of 2023.10-th version). And I need to make this method to use modified configuration externally.
What I'm doing wrong?
Post by aimeos » 17 May 2024, 08:50
Please show your merged ./config/shop.php (without the credentials).
Sabir_Ali
Post by Sabir_Ali » 17 May 2024, 09:01
Sure. Here is in the attachments.
config.shop.tar.gz
(2.46 KiB) Downloaded 1708 times
Post by aimeos » 17 May 2024, 09:06
You've missed the 'controller' key where it must be merged below and guess this won't work too:
'previews' => array_merge(config('controller.common.media.product.previews', []), [
