Customer manager save event
MikaelNazarenko
Expert
Re: Customer manager save event
Post by MikaelNazarenko » 17 Nov 2019, 17:36
Aimeos, thank you for the great support and cooperation! Now seems it works.
My version is:
aimeos/aimeos-core                    2019.10.x-dev 64b1a38 Full-featured e-commerce components for high performance online shops
When I modify simple filed $customer->isModified() returns true, or if I modify nothing it shows false. It is ok. But it doesn't work as I expected for groups. If I add or delete group to customer it shows always false. How can I solve this situation with groups ?
Thank you so much!
Post by aimeos » 20 Nov 2019, 17:54
We fixed a bug that prevented removing all groups from a customer. This is available in aimeos/ai-admin-jqadm 2019.10.x-dev. Can you try if it works now also for you?
MikaelNazarenko
Expert
Post by MikaelNazarenko » 20 Nov 2019, 21:42
I was hoping it will work(( but it doesn't (( The log is:
[20-Nov-2019 21:38:44 UTC] modified: customer.groups :: NULL -> array (
  0 => 1,
Packages versions when I tried:
aimeos/ai-admin-jqadm                 2019.10.x-dev ac5080a Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2019.10.2             Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2019.10.8             Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2019.10.1             Aimeos JSON API extension
aimeos/ai-controller-frontend         2019.10.3             Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2019.10.3             Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2019.10.1             Aimeos Gettext extension
aimeos/ai-laravel                     2019.10.2             Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-payments                    2019.10.1             Payment extension for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer                 2019.10.1             SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core                    2019.10.5             Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel                 2019.10.1             Professional, full-featured and high performance Laravel e-commerce package for online shops and complex B2B projects
I also executed
composer clearcache
to grab fresh files...
I ask you and hope it will be fixed soon..
Thank you!
Post by aimeos » 21 Nov 2019, 14:15
You also need: aimeos/aimeos-core 2019.10.x-dev
MikaelNazarenko
Expert
Post by MikaelNazarenko » 21 Nov 2019, 15:37
Yes now it works! But is I modify groups $customer->isModified() returns false; How can I check if groups were modified ? I mean add or remove groups from customer ?
I need it for all related customer objects. Yes I can loop through objects and check if object was modified for example address. But can I check if address was deleted or added to customer ? Not only address or another property. Because if for example address was deleted from customer it means customer was modified..
And can I use those versions in live project ? Those dev versions are ok ?
Post by aimeos » 21 Nov 2019, 17:34
MikaelNazarenko wrote: 21 Nov 2019, 15:37 Yes now it works! But is I modify groups $customer->isModified() returns false; How can I check if groups were modified ? I mean add or remove groups from customer ?
There was a setModified() call in setGroups() missing. That's fixed now.
MikaelNazarenko wrote: 21 Nov 2019, 15:37 I need it for all related customer objects. Yes I can loop through objects and check if object was modified for example address. But can I check if address was deleted or added to customer ? Not only address or another property. Because if for example address was deleted from customer it means customer was modified..
Use those methods to get deleted items:
$item->getAddressItemsDeleted();
$item->getListItemsDeleted();
$item->getPropertyItemsDeleted();
MikaelNazarenko wrote: 21 Nov 2019, 15:37 And can I use those versions in live project ? Those dev versions are ok ?
Yes, 2019.10.x-dev only contains the bugfixes for the LTS branch that are not yet tagged.
MikaelNazarenko
Expert
Post by MikaelNazarenko » 21 Nov 2019, 22:17
Aimeos, thank you so much! It works like I wanted! )
