CSV Import file location setup issue?
Re: CSV Import file location setup issue?
Post by aimeos » 17 Nov 2016, 15:11
Your baseurl seem to be somehow incorrect. The image source should start with "/" because your detail page ist /detail/.../0 and relative paths without leading slash will be fetched as /detail/.../0/files/...jpg
alfredlaggner
Post by alfredlaggner » 28 Nov 2016, 03:35
After doing other work I came back io import pictures. I corrected the baseurl by adding a leading backlash. But now I have a new issue: as you suggested I added the media file name to the csv import. But no matter what I try the filename does not show up within aimeos database system. I tried with typeid = 1 and without typeid. When I manually add an image in the database (just for testing) I get it to display correctly.
This is a step back from my previous attempt where the file name was accepted after import.
Again here are my configuration files and a sample for you to check. This version is without typeid and with media.preview.
"26","default","1","Irie-Protein Bar 175mg","short","Irie-Protein Bar 175mg","long","Irie-Protein Bar 175mg","product","USD","","23","-15.25000000000022","product","USD","","","","product","USD","","","","product","USD","","","","9","1","7","2","protein bar irie.jpg","protein bar irie.jpg"
                        'mapping' => [
                            'item' => [
                                1 => 'product.type', // type of the product, e.g. "default" or "selection"
                                2 => 'product.status', // enabled (1) or disabled (0)
                                3 => 'product.label', // UTF-8 encoded text, also used as product name
                            'text' => [
                                6 => 'text.type', // e.g. "long" for long description
                                7 => 'text.content', // UTF-8 encoded text
                            'price' => [
                                8 => 'price.typeid',
                                9 => 'price.currencyid',
                                10 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                11 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                12 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
                                13 => 'price.typeid',
                                14 => 'price.currencyid',
                                15 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                16 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                17 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
                                18 => 'price.typeid',
                                19 => 'price.currencyid',
                                20 => 'price.quantity', // the quantity the price is valid from (for block pricing)
                                21 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                22 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
                                23 => 'price.typeid',
                                24 => 'price.currencyid',
                                25 => 'price.quantity', // the quantity the price is valid from (for block pricing)Call to a me
                                26 => 'price.value', // price with decimals separated by a dot, no thousand separator
                                27 => 'price.taxrate', // the quantity the price is valid from (for block pricing)
                            'stock' => [
                                28 => 'product.stock.stocklevel',
                                29 => 'product.stock.warehouseid',
                            'catalog' => [
                                30 => 'catalog.list.typeid',
                                31 => 'catalog.code',
                            'media' => [
                                32 => 'media.url',
                                33 => 'media.preview',
Please advise! I am looking forward to your answer. I am using the latest uupdate of aimeos.
Post by aimeos » 28 Nov 2016, 14:13
Your file isn't imported at all because "product" is a domain, no price.typeid value.
And always use "....type" and their codes instead! IDs can change between environments but codes not.
