Aimeos Installation Issue
jyu100
Post by jyu100 » 14 May 2017, 05:03
Brand new install laravel 5.4.23 by using 'laravel new project'
Installed aimeos following instruction on https://github.com/aimeos/aimeos-laravel
When I tried to get to the list page 'http://cart.dev/index/list', I got following error:
NotFoundHttpException in RouteCollection.php line 179:
at RouteCollection->match(object(Request)) in Router.php line 533
at Router->findRoute(object(Request)) in Router.php line 512
at Router->dispatchToRoute(object(Request)) in Router.php line 498
at Router->dispatch(object(Request)) in Kernel.php line 174
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request)) in Pipeline.php line 30
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in TransformsRequest.php line 30
at TransformsRequest->handle(object(Request), object(Closure)) in Pipeline.php line 148
at Pipeline->Illuminate\Pipeline\{closure}(object(Request)) in Pipeline.php line 53
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in ValidatePostSize.php line 27
at ValidatePostSize->handle(object(Request), object(Closure)) in Pipeline.php line 148
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in CheckForMaintenanceMode.php line 46
at CheckForMaintenanceMode->handle(object(Request), object(Closure)) in Pipeline.php line 148
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in Pipeline.php line 102
at Pipeline->then(object(Closure)) in Kernel.php line 149
at Kernel->sendRequestThroughRouter(object(Request)) in Kernel.php line 116
at Kernel->handle(object(Request)) in index.php line 53
at require('/Users/johnyu/sites/cart/public/index.php') in server.php line 133
I tried the process several times and the results are the same.
The database did have 74 tables.
My environment:
PHP 7.1.4
MariaDB 10.1.22
MacOS 10.12.4
Laravel 5.4.23
Laravel Valet 2.0.4
Appreciate your help.
Re: Aimeos Installation Issue
Post by aimeos » 14 May 2017, 13:27
The right URL is either http://cart.dev/index.php/list (.php ending) or http://cart.dev/list (without "index")
jyu100
Post by jyu100 » 14 May 2017, 13:55
'http://cart.dev/list' works.
'http://cart.dev/index.php/list' is still getting the same error as before.
Now I have something to go on. Thanks so much for your help :D
