Changing Tax rate base on US states
bill
Post by bill » 30 May 2017, 16:24
Hi
How do I change the tax rate base on US States ,
like for example
Ca >> 9.8%
can you do that? please guide me through it
Also I want to remove the Rebate from checkout, how do we do that
Re: Changing Tax rate base on US states
Post by aimeos » 30 May 2017, 20:47
bill wrote: How do I change the tax rate base on US States , like for example
Ca >> 9.8%
The Aimeos company has an extension for applying tax rates to products based on countries/states:
https://aimeos.com/extensions/
bill wrote: Also I want to remove the Rebate from checkout, how do we do that
Overwrite the basket template and remove the HTML code from the template
bill
Post by bill » 31 May 2017, 18:09
Thanks for your help
