Changing header & body for mini basket?
bill
Post by bill » 20 Jun 2017, 22:06
Hello
I have added two files in my ext folder I have created under >>
client/html/templates/basket/mini/body-default.php
client/html/templates/basket/mini/header-default.php
and in this file I have this code >>
foreach( $this->miniBasket->getProducts() as $product ) {
$quantity += $product->getQuantity();
echo $quantiy;
basically when I call this <?= $aiheader['basket/mini'] ?> I want to return the quanity of the basket??
I added this to my balde template <?= $aiheader['basket/mini'] ?> and its returning empty??
what I am doing wrong here?
Re: Changing header & body for mini basket?
Post by aimeos » 21 Jun 2017, 13:09
Maybe the content of the basket is cached if you didn't configure otherwise in your dev environment:
https://aimeos.org/docs/Configuration/C ... che/enable
bill
Post by bill » 21 Jun 2017, 15:51
aimeos wrote:Maybe the content of the basket is cached if you didn't configure otherwise in your dev environment:
I already have it cached , how can I make sure that when I display this : <?= $aiheader['basket/mini'] ?> . in my blade template I want it to work across the whole site, but right now its not working I am getting undefined error on some pages?
could you help me?
Post by aimeos » 21 Jun 2017, 21:03
OK, if you want to use the mini basket component in your own pages (not only those that are offered by the Aimeos Laravel package by default), you should have a look into this article explaining the details:
https://aimeos.org/docs/Laravel/Create_new_pages
bill
Post by bill » 21 Jun 2017, 21:15
Yes I see your point
but I need to make it available in ALL pages Aimeos and my pages , basically in the header.blade I have created that I need to be able to call that array and it will work?
do I need to create a new serviceprovider?
Post by aimeos » 21 Jun 2017, 21:28
No, you don't. Only configure a new section in your ./config/shop.php:
'page' => array(
    // ... existing entries
    'aimeosall' => array('basket/mini'),
Add this to your actions:
$params = app( '\Aimeos\Shop\Base\Page' )->getSections( 'mypage' );
// do some more stuff
return \View::make('mypagetmpl', $params);
Then you can use "<?= $aiheader['basket/mini'] ?>" in every template.
bill
Post by bill » 21 Jun 2017, 21:49
for this :
What you mean add to your action? where exactly?
I am not trying to create a new page I just need to use the $aiheader['basket/mini'] in ALL my template
ujackson
Post by ujackson » 21 Jun 2017, 22:07
See the post on Github: https://github.com/aimeos/aimeos-laravel/issues/103
Substitute "catalog/filter" with "basket/mini".
bill
Post by bill » 22 Jun 2017, 15:36
but when you do this in ./config/shop.php you are specifying that variable $aiheader['basket/mini'] in the HOME PAGE only
'page' => array(
		'home' => array( 'catalog/filter' ),
I need to be able to add this variable if I want in my layout blade template and it will used by all the pages without getting error of undefined
right now I get undefined error on the other pages
Post by aimeos » 23 Jun 2017, 15:51
In this case, a common Laravel service provider might be really the best option:
https://laravel.com/docs/5.4/views#shar ... -all-views
There you can inject the output of the "Page" object you've defined in the config for all templates.
