aimeos\shop\ShopServiceProvider not found
pilapila
Post by pilapila » 18 Sep 2017, 00:16
Hi friends
i want to install aimeos but it give me following error:
[Symfony\Component\Debug\Exception\FatalErrorException] ←[39;49m
←[37;41m Class 'Aimeos\Shop\ShopServiceProvider' not found
my project in localhost : xampp\htdocs\aimeosshop\myshop
aimeos\aimeos-laravel-master is in vendor
composer.json
"name": "laravel/laravel",
"description": "The Laravel Framework.",
"keywords": ["framework", "laravel"],
"license": "MIT",
"type": "project",
"prefer-stable": true,
"minimum-stability": "dev",
"require": {
"php": ">=5.6.4",
"laravel/framework": "5.4.*",
"aimeos/aimeos-laravel": "~2017.07",
"laravel/tinker": "~1.0"
"require-dev": {
"fzaninotto/faker": "~1.4",
"mockery/mockery": "0.9.*",
"phpunit/phpunit": "~5.7"
"autoload": {
"classmap": [
"database"
"psr-4": {
"App\\": "app/"
"autoload-dev": {
"psr-4": {
"Tests\\": "tests/"
"scripts": {
"php -r \"file_exists('.env') || copy('.env.example', '.env');\""
"post-create-project-cmd": [
"php artisan key:generate"
"post-install-cmd": [
"Illuminate\\Foundation\\ComposerScripts::postInstall",
"php artisan optimize"
"post-update-cmd": [
"Illuminate\\Foundation\\ComposerScripts::postUpdate",
"php artisan vendor:publish --tag=public --force",
"php artisan vendor:publish",
"php artisan migrate",
"config": {
"preferred-install": "dist",
"sort-packages": true,
"optimize-autoloader": true
config\app.php :
App\Providers\EventServiceProvider::class,
App\Providers\RouteServiceProvider::class,
Aimeos\Shop\ShopServiceProvider::class,
please help me
Re: aimeos\shop\ShopServiceProvider not found
Post by aimeos » 18 Sep 2017, 08:08
Did you execute "composer update" after adding "aimeos/aimeos-laravel": "~2017.07" and before adding the line in the ./config/app.php file?
You can also try the new Aimeos distribution, that does everything for you automatically:
https://github.com/aimeos/aimeos
pilapila
Post by pilapila » 18 Sep 2017, 08:11
yes, i execute
Post by aimeos » 18 Sep 2017, 09:16
Somewhere, you may have made a mistake during setup. Please start from scratch and follow the documentation step by step:
https://github.com/aimeos/aimeos-larave ... -or-update
Alternatively, try the Aimeos distribution: https://github.com/aimeos/aimeos
