Override aimeos class
MirkoPinna
Post by MirkoPinna » 25 Sep 2017, 12:07
Hi i am looking for a way to override the
aimeos-core/lib/mwlib/src/MW/Criteria/Attribute/Standard.php
class.
Is it possible? I want to add one parameter.
Re: Override aimeos class
Post by aimeos » 25 Sep 2017, 20:58
Can you explain which parameter you would like to add for what reason?
MirkoPinna
Post by MirkoPinna » 26 Sep 2017, 07:15
I would like to add a 'hint' parameter, since it actually takes the key as placeholder.
Post by aimeos » 26 Sep 2017, 11:15
The easier way would be to add a translatable hint for the code like realized here:
https://github.com/aimeos/ai-client-htm ... t.php#L124
