Import limit
Bevi
Import limit
Post by Bevi » 02 Oct 2017, 00:16
I've imported more than 25000 products through csv importation but my shop only show 9690 of them.
Is there a limit of records I can have in a single category?
Re: Import limit
Post by aimeos » 02 Oct 2017, 10:23
If no errors occurred for some products during the import (check the madmin_log table) all products have been imported. In the list views, you will see a maximum of 10 000 entries but you can filter the list to get to every product.
Bevi
Re: Import limit
Post by Bevi » 07 Oct 2017, 16:50
Will you fix this? I also notice there is a bug when switching to the last page: it says "page 101 of 100" :)
Re: Import limit
Post by aimeos » 08 Oct 2017, 15:49
If I remember correctly, this is fixed in dev-master and will be part of the release next week.
