My account page showing error.
sumit kaushik
Post by sumit kaushik » 05 Oct 2017, 06:58
After login myaccount page is showing error
Item with ID "" in "customer.id" not found
Users are showing in both database tables and in admin. Please suggest about it.
Re: My account page showing error.
Post by aimeos » 05 Oct 2017, 14:07
Did you changed the "myaccount" route group and removed the "auth" middleware? This can only occur if your user accesses the "My account" page without being logged in. The Laravel authentication redirects the user to the login page if necessary in the standard Laravel auth setup.
sumit kaushik
Post by sumit kaushik » 06 Oct 2017, 06:04
My routes.php file has
Route::group(config('shop.routes.account', ['middleware' => ['web', 'auth']]), function() {
Post by aimeos » 10 Oct 2017, 20:12
Is there a stack trace available in the madmin_log table?
