Get site orders
MirkoPinna
Get site orders
Post by MirkoPinna » 06 Oct 2017, 11:43
Hi is there a way to get all the orders relative to one site from a Laravel controller?
Re: Get site orders
Post by aimeos » 06 Oct 2017, 20:04
Have you read this article?
https://aimeos.org/docs/Laravel/Extend_ ... os_objects
It explains how to access the Aimeos data from a Laravel controller.
MirkoPinna
Re: Get site orders
Post by MirkoPinna » 09 Oct 2017, 08:35
Yes ok but looks like there is no apis to get all the orders from a site. There is the order manager but doesn't seems to be very helpful in this case.
Re: Get site orders
Post by aimeos » 09 Oct 2017, 21:32
A site is defined by its siteid value and that depends on the site code you feed into the bootstrap method of the locale manager to set the locale item in the context object. The order manager will then fetch all orders that match the siteid value from the locale item.
