How to use custom columns/tables
roasted-toast
Post by roasted-toast » 16 Oct 2017, 10:42
I've installed the Aimeos package on top of an existing Laravel 5.4 app and I need to user different column names.
This app uses 2 specific columns names for the user's first and last name:
first_name
last_name
Aimeos uses different columns:
firstname
lastname
Accessing the Aimeos backend shows empty fields for the customers page:
Same for phone, we have:
office_number
mobile_number
When aimeos uses:
telephone
Another problem is that the address, postal code and city columns are being used on a different table (companies, linked with a companies.user_id column).
What would be the best workaround for me to use the existing records inside the ecommerce package without having to duplicate them into the aimeos fields?
Any advice would be most welcome, thanks.
Re: How to use custom columns/tables
Post by aimeos » 16 Oct 2017, 14:44
You can change the SQL statements for retrieving the data or even replace the Laravel implementation of the customer manager to update tables with depending information (address, company, etc.). This thread explains how:
laravel-package-f18/override-ext-ai-laravel-t1135.html
