Aimeos routes
tkristis
Aimeos routes
Post by tkristis » 23 Oct 2017, 19:30
Hi, I can't find aimeos routes.
Where are location of aimeos routes?
I'm using latest version of aimeos.
Thanks for help!
Re: Aimeos routes
Post by aimeos » 23 Oct 2017, 21:18
tkristis
Re: Aimeos routes
Post by tkristis » 25 Oct 2017, 09:53
So if I want to change product listing page name instead "list" to "products" how I could do that?
Re: Aimeos routes
Post by aimeos » 25 Oct 2017, 10:25
Laravel allows you to overwrite routes in the routes/web.php file. Might be something like this:
Route::group(config('shop.routes.default', ['middleware' => ['web']]), function() {
	Route::match( array( 'GET', 'POST' ), 'products', array(
		'as' => 'aimeos_shop_list',
		'uses' => 'Aimeos\Shop\Controller\CatalogController@listAction'
But I'm not 100% sure. If this doesn't work, please ask in the Laravel forums for help.
tkristis
Re: Aimeos routes
Post by tkristis » 25 Oct 2017, 11:18
I get "CatalogController does not exist" error, but thanks I will try to figure it out.
tkristis
Re: Aimeos routes
Post by tkristis » 30 Oct 2017, 11:32
I found a solution.
In config/app.php in the providers array put the service provider of the package before App\Providers\RouteServiceProvider::class, and then in your web.php routes you'll be able to override it with your custom route.
Also need to change route code and add slash.
Instead this:
Do this:
'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction'
https://stackoverflow.com/questions/447 ... ckage?rq=1
