Register/Login
Bevi
Register/Login
Post by Bevi » 08 Nov 2017, 12:40
Version 2017.10
I've noticed you did remove the register and login button from the main page.
Is there a particular reason why you did so?
Re: Register/Login
Post by aimeos » 08 Nov 2017, 18:11
In the aimeos-laravel integration? Don't know if it was there any time before because authentication must be set up by you before this could work
Re: Register/Login
Post by aimeos » 12 Nov 2017, 12:16
In the latest version of the Aimeos distribution, authentication is set up automatically and the site template contains the links for login/register as well as the selector for languages and currencies:
https://github.com/aimeos/aimeos
