Overwrite attributes
Bevi
Post by Bevi » 17 Nov 2017, 19:05
Laravel 2017.10
Hello Sir, :)
I don't understand why it is not possible to overwrite attributes through csv files.
The very first time I've imported the csv, I had no problem with it.
Now I had to manually remove the attributes, because I was getting this error:
Unable to import product with code "TOPR2420": An exception occurred while executing ' INSERT INTO "mshop_product_list" ( "parentid", "typeid", "domain", "refid", "start", "end", "config", "pos", "status", "mtime", "editor", "siteid", "ctime" ) VALUES ( 89776, 2, 'attribute', '10518', NULL, NULL, '[]', 0, 1, '2017-11-17 18:40:48', 'aimeos:jobs', 1, '2017-11-17 18:40:48' ) ': SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '1-attribute-10518-2-89776' for key 'unq_msproli_sid_dm_rid_tid_pid'
What am I supposed to do? I must overwrite attributes through csv, because I receive new price lists every month, and I do map them through a macro I made. :roll:
Check this image, you can see that I get the error the second time I enter the command. Notice that I didn't modify the csv.zip file. :?
Re: Overwrite attributes
Post by aimeos » 18 Nov 2017, 11:09
Updating/overwriting existing records should be no problem. The importer is built for that.
Do you get that error for every of the 5275 lines in your CSV that the importer was not being able to update?
Can you post a minimal file that generates the error? If it contains sensitive data, change them to something different.
Bevi
Post by Bevi » 18 Nov 2017, 16:14
aimeos wrote:Updating/overwriting existing records should be no problem. The importer is built for that.
Hi again, Sir
Ok, here's my whole xlsX file. I deleted the values inside the price column, for privacy. :roll:
Don't worry, there is no vba code inside the file, so you won't think you're going to be infected by some virus. ;)
https://mega.nz/#!7o8SXS7R!5zvl-Cud_Av ... 9-C9cfVdM
Post by aimeos » 19 Nov 2017, 13:32
Please attach a CSV file with a minimum amount of lines only that produces the error.
Bevi
Post by Bevi » 23 Nov 2017, 13:28
Ok, here's 1 single row csv file that produces the error, and the mapping file as well.
https://www.mediafire.com/file/sxm8fsuo ... Aimeos.zip
Post by aimeos » 27 Nov 2017, 10:45
Mapping and the line in the CSV file are OK. After creating the referenced category and all attribute types, it imports without problems you can execute the job several times without an error:
./artisan aimeos:jobs product/import/csv default
If there are any errors, you can see them in the madmin_log table.
Here's the configuration we've used for testing in ./config/shop.php:
	'controller' => [
		'jobs' => [
			'product' => [
				'import' => [
					'csv' => [
						'container' => [
							'type' => 'Directory'
						'location' => base_path('import'),
						'skip-lines' => 0,
						'mapping' => [
						'item' => [
								1 => 'product.label', // UTF-8 encoded text, also used as product name
								2 => 'product.type', // type of the product, e.g. "default" or "selection"
								3 => 'product.status', // enabled (1) or disabled (0)
							'text' => [
								6 => 'text.type', // e.g. "short" for short description
								7 => 'text.content', // UTF-8 encoded text
								8 => 'text.type', // e.g. "short" for short description
								9 => 'text.content', // UTF-8 encoded text
								10 => 'text.languageid',
								11 => 'text.type', // e.g. "short" for short description
								12 => 'text.content', // UTF-8 encoded text
								13 => 'text.languageid',
								14 => 'text.type', // e.g. "short" for short description
								15 => 'text.content', // UTF-8 encoded text
								16 => 'text.languageid',
								17 => 'text.type', // e.g. "short" for short description
								18 => 'text.content', // UTF-8 encoded text
								19 => 'text.type', // e.g. "short" for short description
								20 => 'text.content', // UTF-8 encoded text
								21 => 'text.type', // e.g. "short" for short description
								22 => 'text.content', // UTF-8 encoded text
								23 => 'text.type', // e.g. "short" for short description
								24 => 'text.content', // UTF-8 encoded text
								25 => 'text.type', // e.g. "short" for short description
								26 => 'text.content', // UTF-8 encoded text
								27 => 'text.type', // e.g. "short" for short description
								28 => 'text.content', // UTF-8 encoded text
								29 => 'text.type', // e.g. "short" for short description
								30 => 'text.content', // UTF-8 encoded text
								31 => 'text.languageid',
								32 => 'text.type', // e.g. "short" for short description
								33 => 'text.content', // UTF-8 encoded text
								34 => 'text.languageid',
								35 => 'text.type', // e.g. "short" for short description
								36 => 'text.content', // UTF-8 encoded text
								37 => 'text.languageid',
								38 => 'text.type', // e.g. "short" for short description
								39 => 'text.content', // UTF-8 encoded text
								40 => 'text.languageid',
								41 => 'text.type', // e.g. "short" for short description
								42 => 'text.content', // UTF-8 encoded text
								43 => 'text.languageid',
								44 => 'text.type', // e.g. "short" for short description
								45 => 'text.content', // UTF-8 encoded text
								46 => 'text.languageid',
								47 => 'text.type', // e.g. "short" for short description
								48 => 'text.content', // UTF-8 encoded text
								49 => 'text.languageid',
								50 => 'text.type', // e.g. "short" for short description
								51 => 'text.content', // UTF-8 encoded text
								52 => 'text.languageid',
								53 => 'text.type', // e.g. "short" for short description
								54 => 'text.content', // UTF-8 encoded text
								55 => 'text.languageid',
								56 => 'text.type', // e.g. "short" for short description
								57 => 'text.content', // UTF-8 encoded text
								58 => 'text.languageid',
								59 => 'text.type', // e.g. "short" for short description
								60 => 'text.content', // UTF-8 encoded text
							'media' => [
								61 => 'media.type',
								62 => 'media.url', // relative URL of the product image on the server
							'price' => [
								//32 => 'price.quantity', // the quantity the price is valid from (for block pricing)
								63 => 'price.type',
								64 => 'price.value', // price with decimals separated by a dot, no thousand separator
								65 => 'price.currencyid',
								66 => 'price.taxrate', // tax rate with decimals separated by a dot
							'attribute' => [
								67 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								68 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								69 => 'attribute.label',
								70 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								71 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								72 => 'attribute.label',
								73 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								74 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								75 => 'attribute.label',
								76 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								77 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								78 => 'attribute.label',
								79 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								80 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								81 => 'attribute.label',
								82 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								83 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								84 => 'attribute.label',
								85 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								86 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								87 => 'attribute.label',
								88 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								89 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								90 => 'attribute.label',
								91 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								92 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								93 => 'attribute.label',
								94 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								95 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								96 => 'attribute.label',
								97 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								98 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								99 => 'attribute.label',
								100 => 'attribute.type', // e.g. "size", "length", "width", "color", etc.
								101 => 'attribute.code', // code of an existing attribute, new ones will be created automatically
								102 => 'attribute.label',
							'product' => [
								14 => 'product.code', // e.g. EAN code of another product
								15 => 'product.lists.type', // e.g. "suggestion" for suggested product
							'property' => [
								16 => 'product.property.value', // arbitrary value for the corresponding type
								17 => 'product.property.type', // e.g. "package-weight"
							'catalog' => [
								103 => 'catalog.code', // e.g. Unique category code
								//19 => 'catalog.lists.type', // e.g. "promotion" for top seller products
							'stock' => [
								104 => 'stock.stocklevel', // e.g. Unique category code
Bevi
Post by Bevi » 27 Nov 2017, 15:21
Is there a way to reset every product related table in the database?
I mean, without having to reinstall the whole thing. :mrgreen:
Post by aimeos » 27 Nov 2017, 22:05
You can delete all entries in the mshop_product table using a proper SQL statement
Bevi
Post by Bevi » 29 Nov 2017, 17:37
aimeos wrote:You can delete all entries in the mshop_product table using a proper SQL statement
So, will "DELETE FROM mshop_product;" do the job?
There are no other relations I should consider? :roll:
Post by aimeos » 29 Nov 2017, 23:49
The mshop_product_list and mshop_product_property records are deleted automatically due to the foreign key constraints. You should also delete the images, prices and texts of the products:
DELETE FROM mshop_media WHERE domain='product'
DELETE FROM mshop_price WHERE domain='product'
DELETE FROM mshop_text WHERE domain='product'
