preselect (non-first) option for attribute
antonlinderer
Post by antonlinderer » 23 Nov 2017, 13:50
How do you specify a preselect other than the (default) first option for an attribute?
Re: preselect (non-first) option for attribute
Post by aimeos » 23 Nov 2017, 21:19
Only if you add some logic for your options in your own attribute partial:
https://github.com/aimeos/ai-client-htm ... t.php#L159
The easiest way would be to use position "0" for that attribute you want to have pre-selected.
