new install -
phpgraham
new install -
Post by phpgraham » 04 Dec 2017, 11:21
Hi
Just ran a new install
"aimeos/aimeos-laravel": "~2017.10.3"
"php artisan vendor:publish --tag=public --force",
"php artisan vendor:publish",
"php artisan migrate",
composer update
It responded nothing to migrate ?
Is this correct? is there no database tables to install ?
Re: new install - nothing to migrate ?
Post by aimeos » 04 Dec 2017, 11:22
The database tables are created with this command:
./artisan aimeos:setup
phpgraham
Re: new install -
Post by phpgraham » 04 Dec 2017, 11:26
Ignore that post
the next command sets up tables :)
all going well so far..
phpgraham
Re: new install -
Post by phpgraham » 04 Dec 2017, 11:44
I noticed in instructions you have:
To see all components and get everything working, you also need to create your main Blade template in resources/views/app.blade.php.
Laravel 5.5 default install now puts app.blade.php in resources/views/layouts folder
So to get aimeos to work you have to move the app.blade.php file from
resources/views/layout folder
to
resources/views folder
then site is viewable
phpgraham
Re: new install -
Post by phpgraham » 04 Dec 2017, 12:03
i notice all the javascript and css is linked to https://cdnjs.cloudflare.com
the admin site hangs waiting for this download
Is there a way to set up to disable cloudfare linkage and just have local routing of js / css / images ?
for local development server this would be best, i can understand production live server usage of cloudfare is best
Re: new install -
Post by aimeos » 04 Dec 2017, 21:54
You can overwrite the Blade template for the JQAdm interface and replace the cloudflare links by links to local files:
https://github.com/aimeos/aimeos-larave ... .blade.php
