PercentRebate to all products
Kevin
Post by Kevin » 17 Jan 2018, 15:43
I want to add a percenRebate coupon to all products.
But it seems like when I add multiple times "percentrebate.productcode", only one is saved.
Can anyone advise me on the settings?
K.
Re: PercentRebate to all products
Post by aimeos » 17 Jan 2018, 23:36
The value for "percentrebate.productcode" must be the code of the discount product itself that is shown in the basket, not the rebated products. If you have the set up your installation with the demo dataset, the example discount product is that with code "demo-rebate".
