Unable to create a new Site
HimanshuBhandari
Post by HimanshuBhandari » 21 Jan 2018, 08:42
I have a fresh aimeos installation ~2017.10 with laravel 5.5, I created Admin user and now trying to create a Site, but when I navigate to Site section I am unable to see Add button I stuck. Than I followed https://aimeos.org/docs/Laravel/Configu ... iple_shops tutorial to achieve it through console, but I got this error 'Maximum number of connections (2) for "db" exceeded'.
Finally I changes DB name in .env file and created a new DB and ran "php artisan aimeos:setup" without setting default shop, in that case also I got the same exception 'Maximum number of connections (2) for "db" exceeded'.
Re: Unable to create a new Site
Post by aimeos » 21 Jan 2018, 20:07
Can you specifiy your hosting environment please?
HimanshuBhandari
Post by HimanshuBhandari » 22 Jan 2018, 15:46
Hi, Sorry for not specifying required information.
I am using windows 10, and trying aimeos on my local environment.
Anyways, I found that I have make some changes in shop.php uncommenting resource section and uncommenting "jsonadm" from routes to solve CSRF issue {topic1304.html}. Finally I deleted "shop.php" and run composer update solved my problem.
Post by aimeos » 22 Jan 2018, 15:57
Which web server do you use and which MySQL version?
HimanshuBhandari
Post by HimanshuBhandari » 22 Jan 2018, 17:44
aimeos wrote:Which web server do you use and which MySQL version?
MySQL version : 5.7.19 and the default php server by executing "php artisan serve"
I also updated shop.php to achieve https://aimeos.org/docs/Laravel/Configu ... iple_shops before deleting and updating it with
'routes' => array(
	'account' => array('prefix' => '{site}', 'middleware' => ['web', 'auth']),
	'default' => array('prefix' => '{site}', 'middleware' => ['web']),
	'confirm' => array('prefix' => '{site}', 'middleware' => ['web']),
Don't know if it was causing the problem.
Post by aimeos » 22 Jan 2018, 21:38
No, that shouldn't be the problem. Try the distribution for testing instead like recommended in the other thread.
HimanshuBhandari
Post by HimanshuBhandari » 23 Jan 2018, 18:38
After new installation as suggested in this post5511.html thread, I am able to enable currency and save for the first time, in second time either I got logged out automatically or got the same page expired error.
We can continue discuss this problem on another linked thread.
