custom order id
antonlinderer
custom order id
Post by antonlinderer » 21 Jan 2018, 15:52
How would I go to use custom order id's instead of the standard id for orders which is now AUTO_INCREMENT ?
I was thinking of overriding the aimeos-core file located in lib/mshoplib/src/MShop/Order/Manager/Base/Address/Standard.php
Is that the right approach and how would I do that? Thanks.
Travin
Re: custom order id
Post by Travin » 21 Jan 2018, 16:50
Hey
I think you can extend it by placing here your custom version. I hope so, i'm not sure :roll:
\ext\your-ext\lib\custom\src\MShop\Order\Manager\Base\Address\Standard.php
Re: custom order id
Post by aimeos » 21 Jan 2018, 19:54
@anton: What do you want to achieve? Can you post your alternative table structure?
antonlinderer
Re: custom order id
Post by antonlinderer » 21 Jan 2018, 22:17
I would like to have my order id's as unix timestamps instead of AUTO_INCREMENT integers.
Re: custom order id
Post by aimeos » 22 Jan 2018, 15:56
We wouldn't recommend that. What if you have two orders in the same second?
antonlinderer
Re: custom order id
Post by antonlinderer » 22 Jan 2018, 19:20
Excellent point!
I should forget about this.
Thanks for the feedback.
