custom logo issue for payment emails
antonlinderer
Post by antonlinderer » 24 Jan 2018, 08:54
I have set up a custom logo absolute path in config/shop.php for payment emails but when I run a cron job for emails I receive an error message as follows:
In Swift.php line 206:
Call to undefined method Swift_EmbeddedFile::newInstance()
I am using aimeos 2017.10
Re: custom logo issue for payment emails
Post by aimeos » 24 Jan 2018, 21:52
Unbound composer version constraints like ">=4.0" are a great way to get in trouble later ...
If you execute "composer update" you will get Swiftmailer 5.x with works with 2017.10
antonlinderer
Post by antonlinderer » 24 Jan 2018, 22:00
That's my point...in the composer.lock it is defined as:
"swiftmailer/swiftmailer": ">=4.0"
Post by aimeos » 24 Jan 2018, 22:06
We've released a new version a few minutes ago. Did you already update?
antonlinderer
Post by antonlinderer » 24 Jan 2018, 22:10
just did a "composer update" but there are no updates yet...
Post by aimeos » 24 Jan 2018, 22:12
It might take some minutes but it's already on packagist:
https://packagist.org/packages/aimeos/a ... #2017.10.2
antonlinderer
Post by antonlinderer » 24 Jan 2018, 22:15
ok thanks for your support.... will try some time later.
antonlinderer
Post by antonlinderer » 25 Jan 2018, 08:24
update is not working as there is probably a conflict with laravel/framework which uses swiftmailer/swiftmailer: ~6.0
Post by aimeos » 25 Jan 2018, 13:22
Good point. We've backported the changes to 2017.10 and allowed swiftmailer:~6.0 in the composer.json. Now you should be able to get a working version.
antonlinderer
Post by antonlinderer » 25 Jan 2018, 14:57
Thanks! Now it is working.
