locale decimal separator
antonlinderer
Post by antonlinderer » 30 Jan 2018, 11:42
Is there a way to set up a locale in Aimeos Laravel for a decimal separator such as for typo3 as can be seen at: https://aimeos.org/docs/TYPO3/Configure ... d_currency ?
Thanks.
Re: locale decimal separator
Post by aimeos » 30 Jan 2018, 18:18
You can use the same settings, e.g. "client/html/common/format/separatorDecimal" to set the decimal separator. The only limitation in Laravel is that it can't be easily done for each language separately ...
antonlinderer
Post by antonlinderer » 30 Jan 2018, 18:46
yes that's a limitation. I need it for non-English and English values. So I might need to implement a locale check just before the value is represented to the user...
