Can't fetch attributes images at suggested products
Travin
Post by Travin » 03 Feb 2018, 03:24
Hi all!
I can't fetch images of atributes of suggested products.
I have suggested products at my client\html\templates\catalog\detail\body-default.php
<?php if( ( $posItems = $this->detailProductItem->getRefItems( 'product', null, 'suggestion' ) ) !== []
            && ( $products = $getProductList( $posItems, $this->get( 'detailProductItems', [] ) ) ) !== [] ) : ?>
            <section class="catalog-detail-suggest">
                <?= $this->partial(
                    $this->config( 'client/html/common/partials/products', 'common/partials/products-atpack.php' ),
                    array( 'products' => $products, 'itemprop' => 'isRelatedTo' )
            </section>
        <?php endif; ?>
At the suggested product I have the same code for including attributes like into the single product
<div class="items-attribute items-attribute<?=$productItem->getId();?>">
                    <?= $this->partial(
                        'common/partials/attribute-custom.php',
                        array(
                            'productItem' => $productItem,
                            'attributeItems' => $this->get( 'attributeItems', [] ),
                            'attributeConfigItems' => $productItem->getRefItems( 'attribute', null, 'config' ),
                            'attributeCustomItems' => $productItem->getRefItems( 'attribute', null, 'custom' ),
                            'attributeHiddenItems' => $productItem->getRefItems( 'attribute', null, 'hidden' ),
                            'subClass' => $productItem->getId()
                </div>
Finally, at my attribute-custom.php I am recieving attribute's images.
<?php
foreach( $attribute->getListItems( 'media', 'default' ) as $listItem ) :
echo 'cool! I'm attribute's image!';
endforeach;
But this code is working only at the single product. I can't fetch images of atributes of suggested products. What can I do?
Re: Can't fetch attributes images at suggested products
Post by aimeos » 04 Feb 2018, 15:37
In 2017.10, second level references (images of attributes fetched along with products) are not available automatically. This is the case since 2018.01. Before, you have to match with the items in "attributeItems", which contains those images.
