Images attributes aimeos 2018.1
Travin
Post by Travin » 06 Feb 2018, 12:52
Hey guys
At my 2017.10 I had the code \client\html\templates\catalog\detail\image-partial-bottom.php:
$getVariantData = function( $mediaId, array $mediaItems ) use ( $enc )
	$string = '';
	if( isset( $mediaItems[$mediaId] ) )
		foreach( $mediaItems[$mediaId]->getRefItems( 'attribute', null, 'variant' ) as $id => $item ) {
			$string .= ' data-variant-' . $item->getType() . '="' . $enc->attr( $id ) . '"';
	return $string;
I just switched ->getRefItems( 'attribute', null, 'variant' ) to ->getRefItems( 'attribute', null, 'default' ). And it's worked at 2017.10, i recieved images attributes. Now at 2018 I can't recieve images attributes http://joxi.ru/ZrJepXyU17YpxA
According to axplanation of public function getRefItems ( $domain = null, $type = null, $listtype = null, $active = true )
* @param string|null $domain Name of the domain (e.g. product, text, etc.) or null for all
* @param array|string|null $type Name/Names of the item type or null for all
* @param array|string|null $listtype Name/Names of the list item type or null for all
* @param boolean $active True to return only active items, false to return all
* @return array List of items implementing \Aimeos\MShop\Common\Item\Iface
I tried $mediaItems[$mediaId]->getRefItems( null, null, null, false )
Nothing. Can't access to image data
At my mshop_product_list I have a row
http://joxi.ru/Dr83N6EukbQNJA
Re: Images attributes aimeos 2018.1
Post by aimeos » 07 Feb 2018, 11:08
In 2018.01 it's much easier than before because attributes and properties of media items are available bei default, e.g.:
foreach( $product->getListItem( 'media' ) as $listItem ) {
    $config = $listItem->getConfig();
    if( ( $refItem = $listItem->getRefItem() ) !== null ) {
        $mediaAttributes = $refItem->getRefItems( 'attribute' );
        $mediaProperties = $refItem->getPropertyItems();
Travin
Post by Travin » 08 Feb 2018, 10:45
much easier, cool :)
