Different sets of fields
Travin
Post by Travin » 25 Feb 2018, 18:09
Hi all!
I'm creating Payment Provider. I want to create 4 necessary fields. But if 5th field is filled too, other 4 become not necessary. How can I do that? Thanks!
Travin
Re: Different sets of fields
Post by Travin » 25 Feb 2018, 18:27
Not actual. Did it with JS
Post by aimeos » 26 Feb 2018, 23:09
Yes, in the frontend you have to use JS. In your service provider, you can check if the constraints are valid in the process() method where you should throw an exception if they are not met.
