Product attribute manipulation
Sergunik
Post by Sergunik » 16 Mar 2018, 14:23
Lets look at documentation (https://aimeos.org/docs/Developers/Libr ... gers_items):
"Usually, it's only rarely necessary to extend existing managers and items because most of the data can be associated to items via the list tables. The data can then be stored as attributes, texts or properties (in case of product items) instead."
But how? How can I use attributes? Where I could find documentation about working with attribute?
I have an issue:
Need to add 1 boolean attribute to product.
The attribute should be readable from product page. And should be changeable on admin product page (simple checkbox).
I know that's covered by attribute but have no idea how?
Travin
Re: Product attribute manipulation
Post by Travin » 17 Mar 2018, 14:30
Please tell more clearly what do you need to do wih it
Post by aimeos » 17 Mar 2018, 17:40
You can associate attributes you've created in the "Attribute" panel of the admin interface in the product detail view ("Characteristics" subpanel). In the template, you can retrieve the attributes again with
$product->getRefItems( 'attribute', '<attribute type>', '<list type>' )
