How to change Homepage URL?
mohal_04
Post by mohal_04 » 27 Mar 2018, 09:46
After installing Aimeos Laravel distribution the home page URL is http://www.example-domain.com/list. Why? And how can I change it?
Laravel version: 5.6
Aimeos version 2017.x
PHP version : 7.x
Thanks!
gladgladwrap
Re: How to change Homepage URL?
Post by gladgladwrap » 27 Mar 2018, 20:48
Check out Laracasts.com and look at how routing works.
Here is the Aimeos routes documentation: https://aimeos.org/docs/Laravel/Custom_routes
Add your routes to your routes/web.
Also take a look at Laravel documentation for which routing methods to use. view() and redirect() are good options.
PHP 7.1.14, Aimeos 2017.10, Laravel 5.5.39 (php artisan --version)
Post by aimeos » 28 Mar 2018, 07:58
You can overwrite routes like this in ./routes/web.php like @gladgladwrap said:
Route::match( array( 'GET', 'POST' ), '', array(
    'as' => 'aimeos_shop_list',
    'uses' => '\Aimeos\Shop\Controller\CatalogController@listAction',
    'middleware' => 'web',
mohal_04
Post by mohal_04 » 29 Mar 2018, 05:40
gladgladwrap wrote:Check out Laracasts.com and look at how routing works.
Thanks!
vasanti94
Post by vasanti94 » 13 Apr 2019, 05:03
Many thanks for sharing such a nice post.
Nurturingtechnolab
Post by Nurturingtechnolab » 25 Apr 2019, 07:21
Thanks for this. while configuring one of my client site I am facing the same issue hope the above tips will fix it.
