Aimeos Laravel Package - How to execute Setup tasks
mohal_04
Post by mohal_04 » 29 Mar 2018, 10:43
Laravel: 5.6
Aimeos: 2017.x
PHP: 7.x
Environment: Linux
I need to add additional field in "mshop_price" table. The field name is "productioncost." So, I studied following link:
https://aimeos.org/docs/Developers/Library/Setup_tasks
and did what is asked. I created "price.php" file in "./ext/myextension/lib/custom/setup/default/schema" directory. Below is the code of "price.php."
https://aimeos.org/docs/Developers/Libr ... ema_update
return array(
	'table' => array(
		'mshop_price' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
			// $table = $schema->createTable( 'mshop_price' );
			$table = $schema->getTable( 'mshop_price' );
			$table->addColumn(  'productioncost', 'decimal', array( 'precision' => 12, 'scale' => 2 ) );
			$table->addIndex( array( 'siteid', 'domain', 'productioncost' ), 'idx_mspri_sid_dom_productioncost' );
			return $schema;
Then I created a Basic Setup Task after reading the following URL:
https://aimeos.org/docs/Developers/Libr ... sks/Basics
I created "PriceAddProductionCost.php" file inside "./ext/myextension/lib/custom/setup" directory. Below is the code:
namespace Aimeos\MW\Setup\Task;
class PriceAddProductionCost extends \Aimeos\MW\Setup\Task\Base
	private $mysql = array(
		'ALTER TABLE "mshop_price" ADD "productioncost" DECIMAL(12,2) NOT NULL AFTER "value"'
	 * Returns the list of task names which this task depends on.
	 * @return string[] List of task names
	public function getPreDependencies()
		return array( 'TablesCreateMShop', 'MShopAddLocaleData' );
	 * Returns the list of task names which depends on this task.
	public function getPostDependencies()
		return [];
	 * Updates the schema and migrates the data
	public function migrate()
	 * Undo all schema changes and migrate data back
	public function rollback()
	 * Cleans up old data required for roll back
	public function clean()
Now, I have three questions.
1. Is Setup file "PriceAddProductionCost.php" necessary to modify table?
2. If Setup file is necessary then kindly guide me if my created file "PriceAddProductionCost.php" is OK?
3. And last question, how to execute Setup file?
Please, reply ASAP!
Thanks!
Re: Aimeos Laravel Package - How to execute Setup tasks
Post by aimeos » 29 Mar 2018, 11:17
No, you don't need the "PriceAddProductionCost.php" file because it's only necessary if you need data migration. Schema changes are made depending on your price.php schema file by the TablesCreateMShop setup task.
You have to run "php artisan aimeos:setup" to update your database.
We are all volunteers helping others for free besides working on our own projects. If you need support within defined reaction time, please ask the Aimeos company for help: https://aimeos.com/support/
mohal_04
Post by mohal_04 » 30 Mar 2018, 06:59
aimeos wrote:No, you don't need the "PriceAddProductionCost.php" file because it's only necessary if you need data migration. Schema changes are made depending on your price.php schema file by the TablesCreateMShop setup task.
Thank you so much! I really appreciate your efforts.
