Custom actions after order is placed
michal.fehér
Post by michal.fehér » 04 Apr 2018, 13:26
Hi. I would like to extend the order functionality. I want to call external API as soon as the new order is placed. What would be the best approach for doing so? Are there any hooks I could use?
Thanks.
Re: Custom actions after order is placed
Post by aimeos » 04 Apr 2018, 22:09
When do you want to step in? Before or after the payment? Does it require an user action or not?
michal.fehér
Post by michal.fehér » 05 Apr 2018, 10:45
Before the payment. It doesnt require an user action, should be automatical.
Post by aimeos » 06 Apr 2018, 08:37
You can implement that as basket plugin listening to the "setOrder.before" event:
- https://github.com/aimeos/aimeos-core/b ... d.php#L467
- https://aimeos.org/docs/Developers/Libr ... et_plugins
Hussnain Sheikh
Post by Hussnain Sheikh » 02 Feb 2019, 13:42
I want to call an external API after the order is created. Is there any hook or event for it? Thanks
Post by aimeos » 02 Feb 2019, 20:00
Depends on what you want to do. Can you tell us what you want to achieve?
