Laravel jsonapi routes
Mightrider
Post by Mightrider » 05 Apr 2018, 10:47
Hello!
If I add an item to my basket, the basket icon on the upper right corner was not updated.
I looked into that issue and apperently all jsonapi requests are not working.
I get the following error message:
ReflectionException
Class api does not exist
in Container.php (line 729)
at ReflectionClass->__construct('api')
at Container->build('api')
in Container.php (line 608)
at Container->resolve('api')
in Container.php (line 575)
at Container->make('api')
in Application.php (line 728)
at Application->make('api')
in Pipeline.php (line 138)
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
in Pipeline.php (line 53)
at Pipeline->Illuminate\Routing\{closure}(object(Request))
in Pipeline.php (line 102)
at Pipeline->then(object(Closure))
in Router.php (line 574)
at Router->runRouteWithinStack(object(Route), object(Request))
in Router.php (line 533)
at Router->dispatchToRoute(object(Request))
in Router.php (line 511)
at Router->dispatch(object(Request))
in Kernel.php (line 176)
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
in Pipeline.php (line 30)
in LogLastUserActivity.php (line 25)
at LogLastUserActivity->handle(object(Request), object(Closure))
in Pipeline.php (line 148)
in VerifyCsrfToken.php (line 65)
at VerifyCsrfToken->handle(object(Request), object(Closure))
in ShareErrorsFromSession.php (line 49)
at ShareErrorsFromSession->handle(object(Request), object(Closure))
in Language.php (line 35)
at Language->handle(object(Request), object(Closure))
in StartSession.php (line 64)
at StartSession->handle(object(Request), object(Closure))
in AddQueuedCookiesToResponse.php (line 37)
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
in EncryptCookies.php (line 59)
at EncryptCookies->handle(object(Request), object(Closure))
in CheckForMaintenanceMode.php (line 46)
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
in Kernel.php (line 151)
at Kernel->sendRequestThroughRouter(object(Request))
in Kernel.php (line 116)
at Kernel->handle(object(Request))
in index.php (line 53)
If I add the following code to my normal laravel route file, the jsonapi OPTIONS is working.
Route::match( array( 'OPTIONS' ), 'jsonapi', array(
	'as' => 'aimeos_shop_jsonadm_options',
	'uses' => '\Aimeos\Shop\Controller\JsonadmController@optionsAction'
))->where( array( 'resource' => '[^0-9A-Z\-\_]*' ) );
Unfortunately it only works with the OPTIONS and not for the other get requests...
This is not working.
Route::match( array( 'GET' ), 'jsonapi/{resource}', array(
	'as' => 'aimeos_shop_jsonapi_get',
	'uses' => '\Aimeos\Shop\Controller\JsonapiController@getAction'
How can I get the jsonapi to work properly?
Did I miss some configuration options?
Re: Laravel jsonapi routes
Post by aimeos » 06 Apr 2018, 08:39
Which Aimeos version and environment are you using?
Mightrider
Post by Mightrider » 06 Apr 2018, 09:19
I have installed Aimeos 2017.10.2 in my existing Laravel 5.4 project.
It is running with PHP 7.1.12 on a Mac.
Post by aimeos » 06 Apr 2018, 10:56
Our Laravel 5.4 test installation runs well with Aimeos 2017.10.2. Did you set up the admin interface too? The code for the boot() method in app/Providers/AuthServiceProvider.php might be required for the JSON REST API as well:
https://github.com/aimeos/aimeos-laravel#admin
Mightrider
Post by Mightrider » 06 Apr 2018, 12:36
I already set up the admin interface before. Changing the code in the boot changed nothing.
Do you have any other idea?
Post by aimeos » 06 Apr 2018, 13:22
Not really. Maybe something from your existing code interferes with the Aimeos routes. You can use
./artisan route:list
to see all available routes. In my Laravel 5.4 installation this looks like:
| Domain | Method        | URI        | Name                         | Action        | Middleware |
|        | GET|HEAD      | /        |                              | Closure        | web        |
|        | GET|HEAD      | admin        | aimeos_shop_admin            | Aimeos\Shop\Controller\AdminController@indexAction                     | web        |
|        | POST          | admin/{site}/extadm/do                                                    | aimeos_shop_extadm_json      | Aimeos\Shop\Controller\ExtadmController@doAction                       | web,auth   |
|        | GET|HEAD      | admin/{site}/extadm/file                                                  | aimeos_shop_extadm_file      | Aimeos\Shop\Controller\ExtadmController@fileAction                     | web,auth   |
|        | GET|HEAD      | admin/{site}/extadm/{lang?}/{tab?}                                        | aimeos_shop_extadm           | Aimeos\Shop\Controller\ExtadmController@indexAction                    | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/copy/{resource}/{id}                                   | aimeos_shop_jqadm_copy       | Aimeos\Shop\Controller\JqadmController@copyAction                      | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/create/{resource}                                      | aimeos_shop_jqadm_create     | Aimeos\Shop\Controller\JqadmController@createAction                    | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/delete/{resource}/{id}                                 | aimeos_shop_jqadm_delete     | Aimeos\Shop\Controller\JqadmController@deleteAction                    | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/export/{resource}                                      | aimeos_shop_jqadm_export     | Aimeos\Shop\Controller\JqadmController@exportAction                    | web,auth   |
|        | GET|HEAD      | admin/{site}/jqadm/file/{type}                                            | aimeos_shop_jqadm_file       | Aimeos\Shop\Controller\JqadmController@fileAction                      | web,auth   |
|        | GET|HEAD      | admin/{site}/jqadm/get/{resource}/{id}                                    | aimeos_shop_jqadm_get        | Aimeos\Shop\Controller\JqadmController@getAction                       | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/import/{resource}                                      | aimeos_shop_jqadm_import     | Aimeos\Shop\Controller\JqadmController@importAction                    | web,auth   |
|        | POST          | admin/{site}/jqadm/save/{resource}                                        | aimeos_shop_jqadm_save       | Aimeos\Shop\Controller\JqadmController@saveAction                      | web,auth   |
|        | GET|POST|HEAD | admin/{site}/jqadm/search/{resource}                                      | aimeos_shop_jqadm_search     | Aimeos\Shop\Controller\JqadmController@searchAction                    | web,auth   |
|        | OPTIONS       | admin/{site}/jsonadm/{resource?}                                          | aimeos_shop_jsonadm_options  | Aimeos\Shop\Controller\JsonadmController@optionsAction                 | web,auth   |
|        | DELETE        | admin/{site}/jsonadm/{resource}/{id?}                                     | aimeos_shop_jsonadm_delete   | Aimeos\Shop\Controller\JsonadmController@deleteAction                  | web,auth   |
|        | PATCH         | admin/{site}/jsonadm/{resource}/{id?}                                     | aimeos_shop_jsonadm_patch    | Aimeos\Shop\Controller\JsonadmController@patchAction                   | web,auth   |
|        | POST          | admin/{site}/jsonadm/{resource}/{id?}                                     | aimeos_shop_jsonadm_post     | Aimeos\Shop\Controller\JsonadmController@postAction                    | web,auth   |
|        | PUT           | admin/{site}/jsonadm/{resource}/{id?}                                     | aimeos_shop_jsonadm_put      | Aimeos\Shop\Controller\JsonadmController@putAction                     | web,auth   |
|        | GET|HEAD      | admin/{site}/jsonadm/{resource}/{id?}                                     | aimeos_shop_jsonadm_get      | Aimeos\Shop\Controller\JsonadmController@getAction                     | web,auth   |
|        | GET|POST|HEAD | basket        | aimeos_shop_basket           | Aimeos\Shop\Controller\BasketController@indexAction                    | web        |
|        | GET|POST|HEAD | checkout        | aimeos_shop_checkout         | \Aimeos\Shop\Controller\CheckoutController@indexAction                 | web        |
|        | GET|POST|HEAD | checkout/{c_step?}                                                        | aimeos_shop_checkout         | Aimeos\Shop\Controller\CheckoutController@indexAction                  | web        |
|        | GET|POST|HEAD | confirm/{code?}                                                           | aimeos_shop_confirm          | Aimeos\Shop\Controller\CheckoutController@confirmAction                | web        |
|        | GET|POST|HEAD | count        | aimeos_shop_count            | Aimeos\Shop\Controller\CatalogController@countAction                   | web        |
|        | GET|POST|HEAD | detail/pin/{pin_action?}/{pin_id?}/{d_prodid?}/{d_name?}/{d_pos?}         | aimeos_shop_session_pinned   | Aimeos\Shop\Controller\CatalogController@detailAction                  | web        |
|        | GET|POST|HEAD | detail/{d_prodid}/{d_name?}/{d_pos?}                                      | aimeos_shop_detail           | Aimeos\Shop\Controller\CatalogController@detailAction                  | web        |
|        | GET|HEAD      | home        |                              | App\Http\Controllers\HomeController@index                              | web,auth   |
|        | OPTIONS       | jsonapi/{resource?}                                                       | aimeos_shop_jsonapi_options  | Aimeos\Shop\Controller\JsonapiController@optionsAction                 | web,api    |
|        | DELETE        | jsonapi/{resource}                                                        | aimeos_shop_jsonapi_delete   | Aimeos\Shop\Controller\JsonapiController@deleteAction                  | web,api    |
|        | GET|HEAD      | jsonapi/{resource}                                                        | aimeos_shop_jsonapi_get      | Aimeos\Shop\Controller\JsonapiController@getAction                     | web,api    |
|        | PATCH         | jsonapi/{resource}                                                        | aimeos_shop_jsonapi_patch    | Aimeos\Shop\Controller\JsonapiController@patchAction                   | web,api    |
|        | POST          | jsonapi/{resource}                                                        | aimeos_shop_jsonapi_post     | Aimeos\Shop\Controller\JsonapiController@postAction                    | web,api    |
|        | PUT           | jsonapi/{resource}                                                        | aimeos_shop_jsonapi_put      | Aimeos\Shop\Controller\JsonapiController@putAction                     | web,api    |
|        | GET|POST|HEAD | list        | aimeos_shop_list             | Aimeos\Shop\Controller\CatalogController@listAction                    | web        |
|        | GET|HEAD      | login        | login                        | App\Http\Controllers\Auth\LoginController@showLoginForm                | web,guest  |
|        | POST          | login        |                              | App\Http\Controllers\Auth\LoginController@login                        | web,guest  |
|        | POST          | logout        | logout                       | App\Http\Controllers\Auth\LoginController@logout                       | web        |
|        | GET|POST|HEAD | myaccount        | aimeos_shop_account          | Aimeos\Shop\Controller\AccountController@indexAction                   | web,auth   |
|        | GET|POST|HEAD | myaccount/download/{dl_id}                                                | aimeos_shop_account_download | Aimeos\Shop\Controller\AccountController@downloadAction                | web,auth   |
|        | GET|POST|HEAD | myaccount/favorite/{fav_action?}/{fav_id?}/{d_prodid?}/{d_name?}/{d_pos?} | aimeos_shop_account_favorite | Aimeos\Shop\Controller\AccountController@indexAction                   | web,auth   |
|        | GET|POST|HEAD | myaccount/watch/{wat_action?}/{wat_id?}/{d_prodid?}/{d_name?}/{d_pos?}    | aimeos_shop_account_watch    | Aimeos\Shop\Controller\AccountController@indexAction                   | web,auth   |
|        | POST          | password/email                                                            | password.email               | App\Http\Controllers\Auth\ForgotPasswordController@sendResetLinkEmail  | web,guest  |
|        | GET|HEAD      | password/reset                                                            | password.request             | App\Http\Controllers\Auth\ForgotPasswordController@showLinkRequestForm | web,guest  |
|        | POST          | password/reset                                                            |                              | App\Http\Controllers\Auth\ResetPasswordController@reset                | web,guest  |
|        | GET|HEAD      | password/reset/{token}                                                    | password.reset               | App\Http\Controllers\Auth\ResetPasswordController@showResetForm        | web,guest  |
|        | GET|HEAD      | privacy        | aimeos_shop_privacy          | Aimeos\Shop\Controller\PageController@privacyAction                    |            |
|        | GET|HEAD      | register        | register                     | App\Http\Controllers\Auth\RegisterController@showRegistrationForm      | web,guest  |
|        | POST          | register        |                              | App\Http\Controllers\Auth\RegisterController@register                  | web,guest  |
|        | GET|POST|HEAD | stock        | aimeos_shop_stock            | Aimeos\Shop\Controller\CatalogController@stockAction                   | web        |
|        | GET|POST|HEAD | suggest        | aimeos_shop_suggest          | Aimeos\Shop\Controller\CatalogController@suggestAction                 | web        |
|        | GET|HEAD      | terms        | aimeos_shop_terms            | Aimeos\Shop\Controller\PageController@termsAction                      |            |
|        | GET|POST|HEAD | update        | aimeos_shop_update           | Aimeos\Shop\Controller\CheckoutController@updateAction                 |            |
The "composer show" command returns:
aimeos/ai-admin-extadm                2017.10.1  Aimeos ai-admin-extadm extension
aimeos/ai-admin-jqadm                 2017.10.20 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm               2017.10.5  Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html                 2017.10.9  Aimeos ai-client-html extension
aimeos/ai-client-jsonapi              2017.10.3  Aimeos JSON API extension
aimeos/ai-controller-frontend         2017.10.5  Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs             2017.10.4  Aimeos ai-controller-jobs extension
aimeos/ai-gettext                     2017.10.1  Aimeos Gettext extension
aimeos/ai-laravel                     2017.10.1  Laravel adapter for Aimeos web shops and e-commerce solu...
aimeos/ai-payments                    2017.10.2  Payment extension for Aimeos web shops and e-commerce so...
aimeos/ai-swiftmailer                 2017.10.5  SwiftMailer adapter for Aimeos web shops and e-commerce ...
aimeos/aimeos-core                    2017.10.15 Full-featured e-commerce components for high performance...
aimeos/aimeos-laravel                 2017.10.4  Full-featured Laravel web shop package and e-commerce so...
composer/installers                   v1.5.0     A multi-framework Composer library installer
dnoegel/php-xdg-base-dir              0.1        implementation of xdg base directory specification for php
doctrine/annotations                  v1.4.0     Docblock Annotations Parser
doctrine/cache                        v1.6.2     Caching library offering an object-oriented API for many...
doctrine/collections                  v1.4.0     Collections Abstraction library
doctrine/common                       v2.7.3     Common Library for Doctrine projects
doctrine/dbal                         v2.5.13    Database Abstraction Layer
doctrine/inflector                    v1.2.0     Common String Manipulations with regard to casing and si...
doctrine/instantiator                 1.0.5      A small, lightweight utility to instantiate objects in P...
doctrine/lexer                        v1.0.1     Base library for a lexer that can be used in Top-Down, R...
erusev/parsedown                      1.7.1      Parser for Markdown.
fzaninotto/faker                      v1.7.1     Faker is a PHP library that generates fake data for you.
guzzle/guzzle                         v3.9.3     PHP HTTP client. This library is deprecated in favor of ...
hamcrest/hamcrest-php                 v1.2.2     This is the PHP port of Hamcrest Matchers
jakub-onderka/php-console-color       0.1
jakub-onderka/php-console-highlighter v0.3.2
laravel/framework                     v5.4.36    The Laravel Framework.
laravel/tinker                        v1.0.5     Powerful REPL for the Laravel framework.
league/flysystem                      1.0.44     Filesystem abstraction: Many filesystems, one API.
mockery/mockery                       0.9.9      Mockery is a simple yet flexible PHP mock object framewo...
monolog/monolog                       1.23.0     Sends your logs to files, sockets, inboxes, databases an...
mtdowling/cron-expression             v1.2.1     CRON for PHP: Calculate the next or previous run date an...
myclabs/deep-copy                     1.7.0      Create deep copies (clones) of your objects
nesbot/carbon                         1.25.0     A simple API extension for DateTime.
nikic/php-parser                      v3.1.5     A PHP parser written in PHP
omnipay/authorizenet                  2.5.1      Authorize.Net gateway for the Omnipay payment processing...
omnipay/cardsave                      2.1.2      CardSave driver for the Omnipay payment processing library
omnipay/common                        2.5.2      Common components for Omnipay payment processing library
omnipay/mollie                        v3.2.0     Mollie driver for the Omnipay payment processing library
omnipay/paypal                        v2.6.4     PayPal gateway for Omnipay payment processing library
omnipay/sagepay                       2.5.1      Sage Pay driver for the Omnipay PHP payment processing l...
omnipay/stripe                        V2.4.7     Stripe driver for the Omnipay payment processing library
paragonie/random_compat               v2.0.12    PHP 5.x polyfill for random_bytes() and random_int() fro...
phpdocumentor/reflection-common       1.0.1      Common reflection classes used by phpdocumentor to refle...
phpdocumentor/reflection-docblock     4.3.0      With this component, a library can provide support for a...
phpdocumentor/type-resolver           0.4.0
phpspec/prophecy                      1.7.5      Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage             4.0.8      Library that provides collection, processing, and render...
phpunit/php-file-iterator             1.4.5      FilterIterator implementation that filters files based o...
phpunit/php-text-template             1.2.1      Simple template engine.
phpunit/php-timer                     1.0.9      Utility class for timing
phpunit/php-token-stream              2.0.2      Wrapper around PHP's tokenizer extension.
phpunit/phpunit                       5.7.27     The PHP Unit Testing framework.
phpunit/phpunit-mock-objects          3.4.4      Mock Object library for PHPUnit
psr/http-message                      1.0.1      Common interface for HTTP messages
psr/log                               1.0.2      Common interface for logging libraries
psy/psysh                             v0.8.18    An interactive shell for modern PHP.
ramsey/uuid                           3.7.3      Formerly rhumsaa/uuid. A PHP 5.4+ library for generating...
sebastian/code-unit-reverse-lookup    1.0.1      Looks up which function or method a line of code belongs to
sebastian/comparator                  1.2.4      Provides the functionality to compare PHP values for equ...
sebastian/diff                        1.4.3      Diff implementation
sebastian/environment                 2.0.0      Provides functionality to handle HHVM/PHP environments
sebastian/exporter                    2.0.0      Provides the functionality to export PHP variables for v...
sebastian/global-state                1.1.1      Snapshotting of global state
sebastian/object-enumerator           2.0.1      Traverses array structures and object graphs to enumerat...
sebastian/recursion-context           2.0.0      Provides functionality to recursively process PHP variables
sebastian/resource-operations         1.0.0      Provides a list of PHP built-in functions that operate o...
sebastian/version                     2.0.1      Library that helps with managing the version number of G...
swiftmailer/swiftmailer               v5.4.9     Swiftmailer, free feature-rich PHP mailer
symfony/console                       v3.4.7     Symfony Console Component
symfony/css-selector                  v3.4.7     Symfony CssSelector Component
symfony/debug                         v3.4.7     Symfony Debug Component
symfony/event-dispatcher              v2.8.37    Symfony EventDispatcher Component
symfony/finder                        v3.4.7     Symfony Finder Component
symfony/http-foundation               v3.4.7     Symfony HttpFoundation Component
symfony/http-kernel                   v3.4.7     Symfony HttpKernel Component
symfony/polyfill-mbstring             v1.7.0     Symfony polyfill for the Mbstring extension
symfony/polyfill-php70                v1.7.0     Symfony polyfill backporting some PHP 7.0+ features to l...
symfony/process                       v3.4.7     Symfony Process Component
symfony/psr-http-message-bridge       v1.0.2     PSR HTTP message bridge
symfony/routing                       v3.4.7     Symfony Routing Component
symfony/translation                   v3.4.7     Symfony Translation Component
symfony/var-dumper                    v3.4.7     Symfony mechanism for exploring and dumping PHP variables
symfony/yaml                          v3.4.7     Symfony Yaml Component
tijsverkoyen/css-to-inline-styles     2.2.1      CssToInlineStyles is a class that enables you to convert...
vdbelt/omnipay-oppwa                  1.1
vlucas/phpdotenv                      v2.4.0     Loads environment variables from `.env` to `getenv()`, `...
webmozart/assert                      1.3.0      Assertions to validate method input/output with nice err...
zendframework/zend-diactoros          1.7.1      PSR HTTP Message implementations
Please note that Aimeos 2017.10.4 is the latest version and you also should have installed the latest Laravel 5.4.* version.
Mightrider
Post by Mightrider » 06 Apr 2018, 13:38
I fixed it.
The project was not started with Laravel 5.4, so the api middlewareGroup was missing in the Kernel.php file.
    protected $middlewareGroups = [
        'web' => [
        'api' => [
Thank you very much for your help!
