Front-end: Change product image on different selection.
mohal_04
Post by mohal_04 » 28 May 2018, 13:25
Laravel version: 5.5.40
Aimeos version: 2018.04
PHP version: 7
I have added few products that are of type Selection. Can anyone help me? How I can change image on the front-end with the option that is selected?
Eagerly waiting for reply.
Thanks!
Umer
Re: Front-end: Change product image on different selection.
Post by aimeos » 30 May 2018, 07:23
You have to add the article specific images to the variant products. The admin interface associates the variant attributes to them and the frontend will change the images depending on the selected variant attribute. Currently, this work with one variant attribute.
mohal_04
Post by mohal_04 » 11 Jun 2018, 08:19
aimeos wrote:You have to add the article specific images to the variant products. The admin interface associates the variant attributes to them and the frontend will change the images depending on the selected variant attribute. Currently, this work with one variant attribute.
Thanks for the help! I was able to do it easily.
Best regards!
