Unexpected getRebate() value
sixbynine
Post by sixbynine » 05 Jul 2018, 11:28
I'm trying to get the rebate value of the variant of a selection product (its value is 5.00 in mshop_price) with :
$product->getPrice()->getRebate();
returned value : 0.00
Here's a part of the dump of my $product Object. Curiously the rebate is 0.00 (the returned value) in Aimeos\MShop\Price\Item\Standard but 5.00 (the expected value) in Aimeos\MShop\Common\Item\Base.
Is this a bug or do i miss something?
["values":"Aimeos\MShop\Price\Item\Standard":private]=> array(20) {
["price.id"]=> string(3) "213"
["price.siteid"]=> string(1) "1"
["price.typeid"]=> string(1) "3"
["price.currencyid"]=> string(3) "EUR"
["price.domain"]=> string(7) "product"
["price.label"]=> string(0) ""
["price.quantity"]=> string(1) "1"
["price.value"]=> string(4) "3.00"
["price.costs"]=> string(4) "1.00"
["price.rebate"]=> string(4) "0.00"
["price.taxrate"]=> string(4) "6.00"
["price.status"]=> string(1) "1"
["price.mtime"]=> string(19) "2018-06-27 18:40:02"
["price.editor"]=> string(22) "user"
["price.ctime"]=> string(19) "2018-05-26 00:20:50"
["price.type"]=> string(7) "default"
["price.typename"]=> string(8) "Standard"
["currencyid"]=> string(3) "EUR"
["price.taxflag"]=> int(0)
["price.tax"]=> string(6) "0.1800"
["bdata":"Aimeos\MShop\Common\Item\Base":private]=> array(19) {
["price.rebate"]=> string(4) "5.00"
Thank you a lot (as always)!
Re: Unexpected getRebate() value
Post by aimeos » 05 Jul 2018, 16:33
Is this the case after you've added the product to the basket or when does it occur?
sixbynine
Post by sixbynine » 05 Jul 2018, 20:42
Thank you a lot for your answer.
It happens indeed after the product is in the basket.
Ok I found this post, explaining everything !
topic847.html
Sorry for the inconvenience.
sixbynine
Post by sixbynine » 06 Jul 2018, 09:14
So, I read everything about this case.
And I used the ->getPrice()->getRawValues() to get the original rebate.
But I would also like to keep and store the original price rebate value and if I well understand, the field "rebate" in mshop_order table after the order is inserted is used to store the coupons rebate.
What is the best way to store also the original rebate (total only) in the table?
I guess I probably need to add a new field originalrebate in the mshop_order table?
Where do i need to add/write it in the checkout process?
Thank you a lot in advance!
Post by aimeos » 09 Jul 2018, 07:35
In which places you want to show the original rebate value?
sixbynine
Post by sixbynine » 09 Jul 2018, 08:49
In the user account "my orders" page.
Post by aimeos » 09 Jul 2018, 09:08
If you need it only there, the easiest option would be to write a decorator for the account history component that walks over the ordered products of an order and fetch the products with their prices to calculate the rebate amount dynamically. Disadvantage: The rebate amount changes depending on the rebate in the product.
A durable solution would be to calculate the rebate in the order base manager (fetching the products with prices) and storing the rebate amount in a new column in the mshop_order_base table. Then you have to extend the order base item to return that value.
sixbynine
Post by sixbynine » 10 Jul 2018, 10:35
I prefer the second option because indeed the rebate amount could change in the time. Thank you very much !
kdim95
Post by kdim95 » 23 Jan 2023, 12:09
I am also facing the same problem, the original rebate value is not accessible in the basket /shop/basket.
I am looking at the mshop_order_base and planning to add an original_rebate database migration but I can't find the current order I'm making. Is the order stored in a session before its complete?
What is the correct way to get the rebate that the product was added to the cart with?
aimeos wrote: 09 Jul 2018, 09:08 If you need it only there, the easiest option would be to write a decorator for the account history component that walks over the ordered products of an order and fetch the products with their prices to calculate the rebate amount dynamically. Disadvantage: The rebate amount changes depending on the rebate in the product.
Post by aimeos » 25 Jan 2023, 11:56
kdim95 wrote: 23 Jan 2023, 12:09 I can't find the current order I'm making. Is the order stored in a session before its complete?
Yes, it's stored in the mshop_order_basket table until the customer clicks on "Buy now" at the end of the checkout process.
kdim95 wrote: 23 Jan 2023, 12:09 What is the correct way to get the rebate that the product was added to the cart with?
1.) Create a migration file:
https://aimeos.org/docs/latest/infrastr ... ing-tables
2.) Overwrite this method in the order product item:
https://github.com/aimeos/aimeos-core/b ... #L741-L773
3.) Overwrite this method in the order product manager to use the new item:
https://github.com/aimeos/aimeos-core/b ... 1091-L1103
4.) Configure your new order product manager so it will be used:
mshop/order/manager/base/product/name = '<my new manager name>'
