Customize automated user creation on checkout
Mightrider
Post by Mightrider » 11 Jul 2018, 09:40
Hi there,
I try to customize the user creation during the checkout process.
Currently the columns of 'username' and the 'user_group_id' are empty.
I would like to set a default user group and found something in the configuration, but it is not working as expected. The user group is still empty.
	'client' => [
		'html' => [
			'checkout' => [
				'standard' => [
					'order' => [
						'account' => [
							'standard' => [
								'groupids' => [
									'2'
								'user_group_id' => [ // thats the name of the column in the database
									'3'
For the username i just want to use the email-address. Is there a way to achieve that?
Thank you in advance for your support!
Local installation, MacOS High Sierra
php: 7.1.4,
laravel/framework: 5.4,
aimeos/aimeos-laravel: 2018.04
Re: Customize automated user creation on checkout
Post by aimeos » 12 Jul 2018, 12:17
The configuration setting for this changed. Use https://aimeos.org/docs/Configuration/C ... r/groupids instead
