How to get the value of entitties.
bharti8800
Sorry if this question sounds stupid but i need some help.
So, this is my controller code:
<?php
namespace App\Http\Controllers;
use Illuminate\Http\Request;
class ProductsController extends Controller
public function index()
$context = app( '\Aimeos\Shop\Base\Context' )->get();
$manager = \Aimeos\MShop\Factory::createManager( $context, 'product' );
$search = $manager->createSearch(true);
$expr = array(
$search->compare( '=~', 'product.code', 'demo-' ),
$search->getConditions(),
$search->setConditions( $search->combine( '&&', $expr ));
$search->setSortations( array( $search->sort( '+', 'product.id' )));
$search->setSlice( 0, 5 );
$total = 0;
$result = $manager->searchItems( $search, array( 'text' ), $total );
print_r($result);
$x=array();
foreach($result as $id => $item ) {
//???????How do i access Product label. I know I will get an object result with all the data. I can access the product id by $id. But how to access the product label,code,price etc.
I know this is a stupid question. Please help me...
<?php
$expr = array(
$total = 0;
print_r($result);
$x=array();
bharti8800
Re: How to get the value of entitties.
Also how to get the value of price. i dont see any price in the return object?
Do we have to add something while creating the manager?
Please have a look at the API: https://aimeos.org/api/latest/class-Aim ... Iface.html
The product item has a method getLabel() and getName() as well as getRefItems(). Using the later one, you can get the prices, media, attributes, etc. if you add the required domain to the second parameter of searchItems():
$items = $manager->searchItems( $criteria, ['price', 'media', 'attribute' /* , ... */ );
foreach( $items as $item ) {
$item->getRefItems( 'price' /* ... */ );
bharti8800
ok so i am able to fetch everything. Just 1 more problem.
How to get the currency symbol displayed????
For USD- $
is there a function for that.??
For USD- $
Use this code:
$this->getContext()->getI18n()->dt( 'currency', 'EUR' );Professional support and custom implementation are available at Aimeos.com
