Custom Menu Element Admin Panel
jramirezgranada
Post by jramirezgranada » 12 Jul 2018, 20:27
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.x
Hi Everyone;
I'm working with aiemos 2018.04 version and I'm trying to get a new element in the admin panel, I followed your recommendation laravel-package-f18/admin-dashboard-add ... html#p6043, so far everything good, when I try to get the element in the menu I overwrite in my own extension the admin.php file with the new element, I added it in navbar and resources array. But I can't get it.
Other options I tried:
1. Created navbar.php file (does not work)
2. Added navbar array in my shop.php config file (does not work)
3. Added my new option in the admin.php file for ai-admin-jqadm extension (it works)
Can you help me with that?
Thanks in advance.
Jorge A Ramirez
System Engineer
PHP Developer
jramirezgranada
Re: Custom Menu Element Admin Panel
Post by jramirezgranada » 12 Jul 2018, 20:49
Thanks,
I've fixed, I had to change the path in the config array in the manifest.php.
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 14 Jul 2018, 08:08
Configuration settings should go to ./yourext/config/ i.e. ./yourext/config/admin.php in your case
