Getting exception while accessing multi shop
I have created second shop in addition to the 'default' one but getting following error while accessing this second shop.
"Locale item for site "kitchen" not found"
I have already added locale currency and language using admin interface.
Will appreciate any help.
Regards/ Mubashir
My Config:
Windows 8.1
PHP 7.2.7
Laravel Framework 5.6.29
aimeos 2018.7
Regards/ Mubashir
My Config:
Windows 8.1
PHP 7.2.7
aimeos 2018.7
Re: Getting exception while accessing multi shop
But did you also add your site/language/currency combination in the "Locale" panel?
Please activate the new site "kitchen" too. It's disabled by default.
Can you please tell me how , sorry for the dumb question.
Regards/
Mubashir
Regards/
Mubashir
Ok, I have found and enabled it. It is now working, Thanks for your urgent replies.
Best regards,
Mubashir
Best regards,
Mubashir
