Extend Catalog
jramirezgranada
Extend Catalog
Post by jramirezgranada » 08 Aug 2018, 19:12
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.x
Hi there;
I've added new fields to others domains like attributes and they worked as expected, now I'm trying to add new fields to Catalog domain but Always I get the error that number of binds doesn't match, I've debugged the process to insert a new catalog item and I found that you use DBNestedSet class, Do i have to extend this class ? or can you explain to me how can I do this ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Extend Catalog
Post by aimeos » 09 Aug 2018, 15:56
The nested set tree manager is shared so you shouldn't change it.
Instead, you can adapt the config and the updateUsage() method of the catalog manager:
- https://github.com/aimeos/aimeos-core/b ... g.php#L246
- https://github.com/aimeos/aimeos-core/b ... d.php#L821
jramirezgranada
Re: Extend Catalog
Post by jramirezgranada » 09 Aug 2018, 19:21
Hey Thanks, it works ... :D :D
Jorge A Ramirez
System Engineer
PHP Developer
