Get Attribute detail
jramirezgranada
Post by jramirezgranada » 13 Aug 2018, 20:32
Hi there;
So i'm trying to show some additional information in the basket.
I have set up a hidden attribute for a product, and the attribute has a specific price,
I get the hidden type attributes with this line in detail-standard.php
$product->getAttributes('hidden')
But I need to get the attribute detail information to show in the basket.
Is there a way from the view to get that needed information?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Get Attribute detail
Post by aimeos » 15 Aug 2018, 15:48
Unfortunately not. The attribute information in the basket/order only contains type/key/value triples but not information that is attached to the original attribute item like its price.
If you want to show that information in the frontend, you have to create a HTML client decorator that fetches the original attribute items and add those to the view: https://aimeos.org/docs/Developers/Html ... components
