Good pratices to improve performances !
sixbynine
Post by sixbynine » 27 Aug 2018, 09:38
I'm still testing aimeos in dev mode and it works very well ! Thank you very much for Aimeos, it is an awesome project.
I'd like to use it in production soon.
For the moment, I still encounter sometimes very long time responses.
I.e : adding a product to the basket with JSONAPI can sometimes take 5000 ms !
I'm not sure it comes from a misconfiguration or aimeos itself because my server is not a racing beast.
But anyway, before upgrading my server configuration, I would like to know if there is somewhere a documentation or information about what I need to take care of to publish my aimeos project with the best performances (i.e. caching, etc.).
Thank you very much in advance one more time,
sbn
Re: Good pratices to improve performances !
Post by aimeos » 29 Aug 2018, 21:22
If basket interactions are slow you should first check your basket plugins and test how long they need to do their job
FAB
Post by FAB » 19 Sep 2018, 00:52
Hi, same problem here, extremly slowwww. Almost impossible to use. Did you figure out a way to improve the performances?
Post by aimeos » 21 Sep 2018, 12:17
Normally, Aimeos is blazing fast. There's one thing that drastically hurts performance: Please have a look if open_basedir is disabled. Otherwise, the realpath cache is disabled too and this makes Aimeos almost unusable.
