Extend Salutation
Mightrider
Extend Salutation
Post by Mightrider » 29 Aug 2018, 07:52
Laravel: 5.4
Aimeos: 2018.04
PHP: 7.1.4
I want to add Dr. as salutation in the address during the checkout.
In the documentation it is written that I need to adapt "a few areas" in the source code.
Do you have any recommendation how to approach this and which Controllers etc. I need to extend?
Thx in advance for your help!
Re: Extend Salutation
Post by aimeos » 29 Aug 2018, 21:30
There's a title property (varchar) you should use for this and you can add a select box if you like in the checkout address templates
