Use Titel during checkout
Mightrider
Post by Mightrider » 29 Aug 2018, 08:57
Laravel: 5.4
Aimeos: 2018.04
PHP: 7.1.4
I wanted to add an optional Title field to the checkout process. After some digging I realized that the according entry is already present in the database and in the Base class:
\Aimeos\MShop\Common\Item\Address\Base.php
Unfortunately I can not enable it via the settings:
https://aimeos.org/docs/Configuration/C ... g/optional
What is the best way to enable the title?
Thx in advance for your help!
Re: Use Titel during checkout
Post by aimeos » 29 Aug 2018, 21:36
The markup for the title is missing here:
https://github.com/aimeos/ai-client-htm ... rd.php#L42
If you change that template, can you also create a pull request to share your code? :-)
