MYACCOUNT did not shows user information
FionLeo1804
Post by FionLeo1804 » 21 Sep 2018, 09:56
Hi, I had setup /myaccount page for my customer.
However, I only saw order history. How can I extend the profile template into /myaccount?
Much appreciate for the helps!
Re: MYACCOUNT did not shows user information
Post by aimeos » 21 Sep 2018, 12:33
There's also the products favorites and the watched products shown if there are any added by the customer. There's also a "profile" component, that's currently empty. Here you can add new subparts for managing other profile data if you want: https://aimeos.org/docs/Developers/Html ... w_subparts
The reason why there's no way to manage the users profile data by default in the MyAccount area is that users can do that during the checkout in the address page without the need to change to the MyAccount area.
FionLeo1804
Post by FionLeo1804 » 22 Sep 2018, 04:23
aimeos wrote:There's also the products favorites and the watched products shown if there are any added by the customer. There's also a "profile" component, that's currently empty. Here you can add new subparts for managing other profile data if you want: https://aimeos.org/docs/Developers/Html ... w_subparts
Well noted. Thanks for the quite reply.
