New Images for Product
jramirezgranada
Post by jramirezgranada » 01 Nov 2018, 16:02
Hi there;
we have one image for a product but multiple sizes, can I upload only one image and do multiple resizes and save it as product images in the admin ?
Is there a way to do that, or i need to create a custom function for that ??
Jorge A Ramirez
System Engineer
PHP Developer
Re: New Images for Product
Post by aimeos » 02 Nov 2018, 09:26
Currently, the image you upload is used and a preview image is generated automatically (you can configure the max. width/height for both if they should be scaled). The "<picture/>" tag for several image sizes is not yet supported but that would be great. If you like to contribute that feature we would love to integrate it into Aimeos :-)
