Get parent product
jramirezgranada
Get parent product
Post by jramirezgranada » 27 Nov 2018, 14:20
Hi there;
I have a selection products with 3 variants product, is there a way to know what is the parent product of those variants ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Get parent product
Post by aimeos » 27 Nov 2018, 17:11
You can search for the parent product in 2018.10 using:
$manager = \Aimeos\MShop\Factory::createManager( $context, 'product' );
$criteria = $manager->createSearch();
$func = $criteria->createFunction( 'product:has', ['product', 'default', '<prodid>'] );
$criteria->setConditions( $criteria->compare( '!=', $func, null ) );
$items = $manager->searchItems( $criteria );
jramirezgranada
Post by jramirezgranada » 27 Nov 2018, 17:18
Does it work in 2017.07 ?
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 27 Nov 2018, 17:20
No, but you should update nevertheless because 2018.07 isn't supported any more 2018.10 is the new LTS version.
jramirezgranada
Post by jramirezgranada » 27 Nov 2018, 17:22
Sorry 2018.07, it does it work in that version?
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 28 Nov 2018, 23:43
Also no. It's new in 2018.10 and you should upgrade too. The upgrade between that versions should be smooth.
