Error during install demo data
D-Cell
Post by D-Cell » 17 Dec 2018, 18:14
Hi everyone! Hope someone can help me to fix my problem.
I would like to try Aimeos on my localhost.
Configuration is Linux Fedora 28, PHP 7.2.13, Mariadb 10.2.19, Nginx.
I followed all instructions from docs and tried to install Aimeos both ways:
- Install as a separate package - composer create-project aimeos/aimeos .
- Install Aimeos 2018.10.3 on clean laravel 5.7 skeleton application
But each time i try to install demo data i`m getting error:
Creating base tables
Using schema from locale.php
Checking table "mshop_locale_site":
In MySqlSchemaManager.php line 315:
Type error: Argument 1 passed to Doctrine\DBAL\Schema\MySqlSchemaManager::p
arseCreateOptions() must be of the type string, null given, called in /var/
www/aimeos.local/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/M
ySqlSchemaManager.php on line 307
I`ll be appreciate for any help.
Best regards to everyone!
D-Cell
Re: Error during install demo data
Post by D-Cell » 17 Dec 2018, 22:11
This is what i get after i run "php artisan aimeos:setup --option=setup/default/demo:1" when install on clean Laravel:
/*Console output is too long, so i provide only the part with error*/
Migrating order type
  Checking table "mshop_order":                                       OK
Remove left over Laravel user address records                         OK
Remove left over Laravel user list records                            OK
   Symfony\Component\Debug\Exception\FatalThrowableError  : Argument 1 passed to Doctrine\DBAL\Schema\MySqlSchemaManager::parseCreateOptions() must be of the type string, null given, called in /var/www/aimeos.local/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/MySqlSchemaManager.php on line 307
  at /var/www/aimeos.local/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/MySqlSchemaManager.php:315
    311|
    312|     /**
    313|      * @return string[]|true[]
    314|      */
  > 315|     private function parseCreateOptions(string $string) : array
    316|     {
    317|         $options = [];
    318|
    319|         if ($string === '') {
  Exception trace:
  1   Doctrine\DBAL\Schema\MySqlSchemaManager::parseCreateOptions()
      /var/www/aimeos.local/public_html/vendor/doctrine/dbal/lib/Doctrine/DBAL/Schema/MySqlSchemaManager.php:307
  2   Doctrine\DBAL\Schema\MySqlSchemaManager::listTableDetails("mshop_locale_site")
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:190
  Please use the argument -v to see more details.
D-Cell
Post by D-Cell » 17 Dec 2018, 22:25
Here is verbose output:
Exception trace:
  3   Aimeos\MW\Setup\Task\TablesCreateMShop::setupSchema()
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-core/lib/mshoplib/setup/TablesCreateMShop.php:107
  4   Aimeos\MW\Setup\Task\TablesCreateMShop::migrate()
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:174
  5   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:170
  6   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
  7   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
  8   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
  9   Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
  10  Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:96
  11  Aimeos\MW\Setup\Manager\Multiple::migrate(Object(Aimeos\MW\Setup\Task\MShopAddAttributeData))
      /var/www/aimeos.local/public_html/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/SetupCommand.php:75
  12  Aimeos\Shop\Command\SetupCommand::handle()
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:29
  13  call_user_func_array([])
  14  Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:87
  15  Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Object(Closure))
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:31
  16  Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), [])
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Container/Container.php:572
  17  Illuminate\Container\Container::call()
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Console/Command.php:183
  18  Illuminate\Console\Command::execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
      /var/www/aimeos.local/public_html/vendor/symfony/console/Command/Command.php:255
  19  Symfony\Component\Console\Command\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Console/Command.php:170
  20  Illuminate\Console\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/vendor/symfony/console/Application.php:901
  21  Symfony\Component\Console\Application::doRunCommand(Object(Aimeos\Shop\Command\SetupCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/vendor/symfony/console/Application.php:262
  22  Symfony\Component\Console\Application::doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/vendor/symfony/console/Application.php:145
  23  Symfony\Component\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Console/Application.php:89
  24  Illuminate\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:122
  25  Illuminate\Foundation\Console\Kernel::handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
      /var/www/aimeos.local/public_html/artisan:37
Post by aimeos » 17 Dec 2018, 22:28
That's a bug in the current Doctrine DBAL library (2.9.1):
https://github.com/doctrine/dbal/issues/3410
You can add this to your composer.json file to use the previous version instead until a new one is released:
"doctrine/dbal": "v2.9.0"
D-Cell
Post by D-Cell » 18 Dec 2018, 08:49
aimeos wrote:That's a bug in the current Doctrine DBAL library (2.9.1):
Thank you! Your solution works perfect! I`ll give you a star on github!
Nofnof
Post by Nofnof » 18 Dec 2018, 11:00
Here to say thank you too, I was trying to install the package for 2 hours and the solution is finally there :)
