During Aimeos Setup Got Errors Laravel
awaidqureshi
Post by awaidqureshi » 12 Jan 2019, 15:23
ErrorException thrown with message "An exception occurred while executing '
SELECT mproty."id" AS "product.type.id", mproty."siteid" AS "product.type.siteid",
mproty."code" AS "product.type.code", mproty."domain" AS "product.type.domain",
mproty."label" AS "product.type.label", mproty."status" AS "product.type.status",
mproty."mtime" AS "product.type.mtime", mproty."editor" AS "product.type.editor",
mproty."ctime" AS "product.type.ctime", mproty."pos" AS "product.type.position"
FROM "mshop_product_type" AS mproty
WHERE ( mproty."siteid" IN (1) AND mproty."id" IN (1) )
GROUP BY mproty."id", mproty."siteid", mproty."code", mproty."domain",
mproty."label", mproty."status", mproty."mtime", mproty."editor",
mproty."ctime"
LIMIT 100 OFFSET 0
SQLSTATE[42S22]: Column not found: 1054 Unknown column 'mproty.pos' in 'field list' (View: C:\xampp\htdocs\nordicforms\resources\views\home\index.blade.php)"
Stacktrace:
#60 ErrorException in C:\xampp\htdocs\nordicforms\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\DB\Statement\DBAL\Simple.php:97
#59 Aimeos\MW\DB\Exception in C:\xampp\htdocs\nordicforms\vendor\aimeos\aimeos-core\lib\mwlib\src\MW\DB\Statement\DBAL\Simple.php:97
#58 Aimeos\MW\DB\Statement\DBAL\Simple:execute in C:\xampp\htdocs\nordicforms\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\Base.php:882
#57 Aimeos\MShop\Common\Manager\Base:searchItemsBase in C:\xampp\htdocs\nordicforms\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Common\Manager\Type\Base.php:233
#56 Aimeos\MShop\Common\Manager\Type\Base:searchItems in C:\xampp\htdocs\nordicforms\vendor\aimeos\aimeos-core\lib\mshoplib\src\MShop\Product\Manager\Standard.php:659
#55 Aimeos\MShop\Product\Manager\Standard:searchItems in C:\xampp\htdocs\nordicforms\storage\framework\views\e1f6f8fcd69278cad29fba7b482f559e5f08b0b5.php:6
#54 include in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\Engines\PhpEngine.php:43
#53 Illuminate\View\Engines\PhpEngine:evaluatePath in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\Engines\CompilerEngine.php:59
#52 Illuminate\View\Engines\CompilerEngine:get in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\View.php:142
#51 Illuminate\View\View:getContents in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\View.php:125
#50 Illuminate\View\View:renderContents in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\View.php:90
#49 Illuminate\View\View:render in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Http\Response.php:42
#48 Illuminate\Http\Response:setContent in C:\xampp\htdocs\nordicforms\vendor\symfony\http-foundation\Response.php:202
#47 Symfony\Component\HttpFoundation\Response:__construct in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:733
#46 Illuminate\Routing\Router:toResponse in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:705
#45 Illuminate\Routing\Router:prepareResponse in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:665
#44 Illuminate\Routing\Router:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:30
#43 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Middleware\SubstituteBindings.php:41
#42 Illuminate\Routing\Middleware\SubstituteBindings:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#41 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#40 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\VerifyCsrfToken.php:68
#39 Illuminate\Foundation\Http\Middleware\VerifyCsrfToken:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#38 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#37 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\View\Middleware\ShareErrorsFromSession.php:49
#36 Illuminate\View\Middleware\ShareErrorsFromSession:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#35 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#34 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Session\Middleware\StartSession.php:63
#33 Illuminate\Session\Middleware\StartSession:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#32 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#31 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse.php:37
#30 Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#29 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#28 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Cookie\Middleware\EncryptCookies.php:66
#27 Illuminate\Cookie\Middleware\EncryptCookies:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#26 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#25 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:104
#24 Illuminate\Pipeline\Pipeline:then in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:667
#23 Illuminate\Routing\Router:runRouteWithinStack in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:642
#22 Illuminate\Routing\Router:runRoute in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:608
#21 Illuminate\Routing\Router:dispatchToRoute in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Router.php:597
#20 Illuminate\Routing\Router:dispatch in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php:176
#19 Illuminate\Foundation\Http\Kernel:Illuminate\Foundation\Http\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:30
#18 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\fideloper\proxy\src\TrustProxies.php:57
#17 Fideloper\Proxy\TrustProxies:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#16 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#15 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php:31
#14 Illuminate\Foundation\Http\Middleware\TransformsRequest:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#13 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#12 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\TransformsRequest.php:31
#11 Illuminate\Foundation\Http\Middleware\TransformsRequest:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#10 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#9 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\ValidatePostSize.php:27
#8 Illuminate\Foundation\Http\Middleware\ValidatePostSize:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#7 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#6 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode.php:62
#5 Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode:handle in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:151
#4 Illuminate\Pipeline\Pipeline:Illuminate\Pipeline\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Routing\Pipeline.php:53
#3 Illuminate\Routing\Pipeline:Illuminate\Routing\{closure} in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Pipeline\Pipeline.php:104
#2 Illuminate\Pipeline\Pipeline:then in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php:151
#1 Illuminate\Foundation\Http\Kernel:sendRequestThroughRouter in C:\xampp\htdocs\nordicforms\vendor\laravel\framework\src\Illuminate\Foundation\Http\Kernel.php:116
#0 Illuminate\Foundation\Http\Kernel:handle in C:\xampp\htdocs\nordicforms\public\index.php:55
Re: During Aimeos Setup Got Errors Laravel
Post by aimeos » 14 Jan 2019, 13:22
Please run "php artisan aimeos:setup" to update your database schema
awaidqureshi
Post by awaidqureshi » 18 Jan 2019, 08:38
aimeos wrote:Please run "php artisan aimeos:setup" to update your database schema
Sir I have done this butt error is still there.so kindly help me about this issue.
Post by aimeos » 18 Jan 2019, 09:30
awaidqureshi
Post by awaidqureshi » 21 Jan 2019, 08:47
aimeos wrote:Which Aimeos version are you using?
"aimeos/aimeos-laravel": "~2018.04",
Post by aimeos » 21 Jan 2019, 09:15
2018.04 isn't supported any more. Please upgrade to 2018.10 LTS
awaidqureshi
Post by awaidqureshi » 24 Jan 2019, 09:16
aimeos wrote:2018.04 isn't supported any more. Please upgrade to 2018.10 LTS
I have updated to latest version butt there is an error of database.
mproty."ctime"
LIMIT 100 OFFSET 0
Post by aimeos » 25 Jan 2019, 07:49
Your database layout doesn't match those expected by the SQL statements. Please run
and watch out for any errors that stop migration to the new DB layout.
