Override cupons providers
jramirezgranada
Post by jramirezgranada » 17 Jan 2019, 21:48
Hi there;
So i need to change some logic from coupons providers, what is the way to override those files, is there a config file or setting to call my new classes ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Override cupons providers
Post by aimeos » 18 Jan 2019, 09:32
Create your own coupon provider and extend from an existing one if you can reuse some code. Your own one should be found automatically and added to the list of available ones in the admin interface.
