How To add New Field In Product Upload Section
awaidqureshi
Post by awaidqureshi » 28 Jan 2019, 16:06
I Want To Add PDF Files (More Than One ) With The Product.Should Be Added In Database.Like Images Are Uploading More Than One So I Want To Add More Than One PDF Files.I Want The Same Scenario.
For Reference :
http://prntscr.com/mdbuq1
So I want A Tab While Adding A Product Like In ScreenShot (Mentioned).
Please Tell Me Complete Step By Step Guide( In Which File I have To Change Things And What To add In Those File For My Scenario) Because I m New Aimeos.
If There Should Some Database Changes Then Please Also Tell Me About How To Do That.
Please Guide Me About My Problem .Thanks !
Re: How To add New Field In Product Upload Section
Post by aimeos » 29 Jan 2019, 06:36
You don't need a new tab because you can upload the PDF files in the "Images" tab (in 2019.x versions it has been renamed to "Media"). Choose "download" as the type of the PDFs and they will be listed in the product detail view for download.
