How to get orders with their products
awaidqureshi
Post by awaidqureshi » 21 Feb 2019, 08:38
I want to get order with their products and their attribute that customer select .
Please tell me step by step guide to get those details.
Secondly Ordered Product with attributes are not saving that what can be the issue that the customer select some attribute while ordering something my system not showing those attributes in the order details.maybe i have done some thing
Please Guide me for those issue that how i can solve that my system show ordered product with their attribute selected .
Re: How to get orders with their products
Post by aimeos » 22 Feb 2019, 09:13
To get the orders of the current customer:
$context = app('\Aimeos\Shop\Base\Context')->get();
$manager = \Aimeos\MShop\Factory::createManager($context, 'order/base');
$search->setConditions($search->compare('==', 'order.base.customerid', $context->getUserId()));
// add 'order/base/address', 'order/base/coupon' and/or 'order/base/service' as well if necessary
$orders = $manager->searchItems($search, ['order/base/product']);
foreach($orders as $order) {
    foreach($order->getProducts() as $orderProducts) {
        foreach($orderProducts->getAttributeItems() as $orderProductAttribute) {
The API docs describe what you can do with the objects: https://aimeos.org/api/latest/class-Aim ... Iface.html
For adding attributes to the ordered products, they must be either of type "variant", "configurable", "custom" or "hidden". Standard attributes won't be added to ordered products.
awaidqureshi
Post by awaidqureshi » 01 Mar 2019, 14:04
i have used these types for attributes that i attach with the product
but when user buy product and select some options .butt when order created order did not save those attributes (Options that user select like size or color) are not saving with the order
for reference :
http://prntscr.com/mrusw9
right now i m getting only name of product
http://prntscr.com/mruuge
And kindly tell me from where i can get the order id right after the order process complete so that i can use it for getting those products details.
Post by aimeos » 03 Mar 2019, 12:15
Did you add variant attributes of the right type? Please show by screenshot
awaidqureshi
Post by awaidqureshi » 04 Mar 2019, 07:14
we are adding Article type products right now.
For options( the way we are attaching them with the product) reference:
https://prnt.sc/msvlz5
maitrishah3
Post by maitrishah3 » 04 Mar 2019, 12:57
awesome this post. cool post
Post by aimeos » 05 Mar 2019, 10:49
Your configurable products look OK. What Aimeos version are you using?
awaidqureshi
Post by awaidqureshi » 06 Mar 2019, 06:34
aimeos wrote:Your configurable products look OK. What Aimeos version are you using?
Thanks for your reply sir. Problem was from my side.
Dhara1510
Post by Dhara1510 » 09 May 2019, 07:23
Hello sir,
This post helps me to get order products.
$context     = App::make('\Aimeos\Shop\Base\Context')->get();
        $baseManager = \Aimeos\MShop::create($context, 'order/base');
        $search      = $baseManager->createSearch();
        $items       = $baseManager->searchItems($search, ['order/base/product']);
        $basket      = reset($items);
        foreach ($basket->getProducts() as $orderProduct)
            foreach($orderProduct->getAttributeItems() as $orderProductAttribute) {
                dd($orderProductAttribute->getParentId());
See my above code. I have added this code in my overridden confirmAction function. It gives me all order details. i need order detail which logged in user created latest order?
Post by aimeos » 09 May 2019, 09:35
Please do not use this code as is because it returns a more or less random order regardless of who placed it!
Which Aimeos version do you use?
