Joins Queries
jramirezgranada
Joins Queries
Post by jramirezgranada » 06 May 2019, 18:54
Hi there;
Is there a way to get users with an associated customer group? or is there a way to do joins queries?
I need to do something like this but with managers
select * from users as u inner join users_list ul on u.id = ul.parentid join mshop_customer_group mcg on cast(ul.refid as integer) = mcg.id
Jorge A Ramirez
System Engineer
PHP Developer
Re: Joins Queries
Post by aimeos » 07 May 2019, 08:30
Easy going: Use "customer/group" for the list of domain names to fetch in getItem(), findItem() or searchItems(), e.g.:
$customerItem = $manager->getItem( 123, ["customer/group"] );
$groupItems = $customerItem->getRefItems( "customer/group" );
jramirezgranada
Re: Joins Queries
Post by jramirezgranada » 07 May 2019, 14:07
Yes, I've worked in that way, and it returns all users even if they don't have an assigned customer group. I want to get only users with an assigned customer group.
Jorge A Ramirez
System Engineer
PHP Developer
Re: Joins Queries
Post by aimeos » 07 May 2019, 15:54
When you've installed 2019.04, you can use the "customer:has" search function:
$func = $search->createFunction( 'customer:has', ['customer/group'] );
$search->setConditions( $search->compare( '!=', $func, null ) );
$items = $manager->searchItems( $search );
jramirezgranada
Re: Joins Queries
Post by jramirezgranada » 07 May 2019, 16:25
Thanks, for previous version is not there a way to do that ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Joins Queries
Post by aimeos » 08 May 2019, 07:50
Not really the same, you can only search for customers that contain a specific user group by its ID with "customer:has". The only alternative is a low level query and feeding the result into the customer manager but that requires in total two queries instead of one.
